Prajekt L: 2700lbs of Fury
Discussion in 'Modifications And Maintenance' started by Justin, Feb 13, 2007.
  1. piddster
    Did you read the FSM on the clutch bleeding procedure? Its fairly specific. I prob went through a whole thing of fluid before I looked at it it and went, doh!
  2. Justin
    Justin Well-Known Member
    no..mike and i did it together.
    whats the specific part?
  3. 95lwrx
    95lwrx Well-Known Member
    self-bleeding clutch :biggrin: that's happened to me when i did bill's tranny, couldn't figure out why i had no pedal feel, but that was because i was bleeding it the old way. so we called mike wray and he said just keep pumping the pedal and after some normal driving it will bleed itself out
  4. piddster
    ^ True. I had to bleed the hell out of mine to get it decent, then a few days later it was nice and firm.
    Justin, the FSM says to slowly depress the clutch pedal to build up pressure. I noticed why; its because you aerate the fluid so you don't get much of the actual air out, since its all foamy.
  5. Justin
    soo...
    crack the bleeder valve, slowly depress the pedal all the way to the floor and hold, tighten back up the bleeder valve ??
  6. 95lwrx
    slowly depress the clutch but leave the bleeder tight i otherwise it doesn't allow the system to bleed itself
  7. subytek
    subytek Well-Known Member
    see if this helps.
  8. GrimmSpeed
    GrimmSpeed Vendor
    i had an issue because we flared the fenders so the stock fender liners didnt fit anymore and with all the ice racing we are doing i need to keep everything clean(wiring, engine bay, etc).
    BEFORE
    AFTER
    Justin
  9. Dynapar
    That looks awesome! I will have to do that once i flare my fenders alittle more. how long did it take to cut everything out?
  10. Jackstand
    Jackstand Well-Known Member
    Pure hottness justin i wish i could have seen it
  11. Grayguy
    Grayguy Well-Known Member
    I want those!
  12. Justin
    hmm, probably took 2 hours from start to finish as far as cutting.
    thanks nick!
    next time i take them off you can copy them if you want.
  13. TRUBLU
    TRUBLU New Member
    Weight thats been added? How much do you think it stacked on?
  14. Justin
    hmm, its pretty thin aluminum. maybe 2lbs per corner.
  15. fondune
    Totally worth it to prevent crap from getting everywhere though...
  16. Paul Revere
    Pretty sweet idea Justin/Grimmspeed crew
  17. Shibbs
    *insert generic ass-kissing comment here*
    :biggrin:
  18. Justin
    now for bringing the cold air to that new engine...
    i'm not exactly sure how i'm going to reroute it when i get the frount mount in but i'm going to have to move it somewhere because right now its right where the passenger side intercooler end tank will sit.
    Justin
  19. Shibbs
    Removable headlight like the Supras do? lawl
    Ooh!! Army jeep snorkel!
  20. curly2k3
    i dont get it, why do it like that if its going to be changed soon again...just ideas?
  21. AspitFire
    why not, its cheap :)
  22. curly2k3
    lmfao, caus the intercooler piping/end tank will be right there... why not just make a duct/intake from your hood scoop if you are running a FMIC anyways?
  23. Justin
    exactly
    because the hood scoop wont be there when the fmic is on
  24. curly2k3
    wait, so why did you cut a hole in your hood then?
  25. Justin
    to get the car running with a tmic. i have an extra hood w/o hole
  26. w_o_t_boy
    w_o_t_boy Well-Known Member
    Projekt L is now Stage 2.
  27. Justin
    got her weighed today...any guesses??
    i was not in the car and there was ~1/2 tank of gas, 30lb set of tools, and a fully inflated wrx wheel as a spare in the car. full interior as well and this is the LX impreza so it has power windows and power doors.
  28. Paul Revere
    2638.72 lbs
  29. curly2k3
    2,300lbs is my guess
  30. Justin
    2300lbs lol i wish...this isnt a civic hatch
    both of you are low. remember there is about 70lbs of extra crap in the car
  31. Paul Revere
  32. curly2k3
    then your not trying hard enough Justin. lol
  33. curly2k3
    ok, serious guess now is 2750, you should be right down around your goal i would assume
  34. Dynapar
    I am gonna guess 2825. the wrx dash/engine/xmember/exhuast are heavier than the stock LX counter parts. so the weight will be up alittle.
  35. Nuke
    2875lbs
    BTW, congrats on getting the car finish.
    Have fun driving it.
  36. w_o_t_boy
    Its not close to finished.
  37. Nuke
    Ok Ok, congrats on getting the car to run...there :)
  38. Justin
    answer is 2810. which is great cause my goal was to keep her around 2700 so if you take out the ~70lbs of crap i had in my car i'm looking at 2740.
  39. Speedemon
    Speedemon Well-Known Member
    nevermind
  40. Nuke
    Just a tad bit late
    Remove all doors, hood, trunk, and just drive without them, much lighter =P
  41. curly2k3
    so once you get your spare garbage out i was right on the money :)
  42. Musashi
    Car looks too skinny, I think you will want to add a few more calories. LOL
    That's going to be a serious factor. So who are you having your suspension setup and weights done?
  43. Justin
    not sure yet actually. i called and chat'd with that jeff the alignment guy...not so sure about him though. you have any recommendations?
  44. Musashi
    I have not personally had mine professionally done as of yet, but I am planning to take my new ride to Orr's Autosports. They seem to know what they are doing and are very competitive in what I do. I dont know how far you're planning on going with this car, and what forum of motorsports your inspired to do but it may be worth while doing it just for the experience. I'm sure you know you'll need more than just an alignment if you want to be competitive, the whole geometry and balance will play a important roll as will a highly qualified driver. Which means getting your rear out to AZ and attend Bondarant Racing School for a few days. LOL
    Best of luck bro, looks like an exciting year for the us both. :laugh:
  45. zyklon
    zyklon Well-Known Member
    Jeff does some corner-weighting work in addition to alignments. I haven't had any work done by him, but it definitely looks like he's worked on some cool stuff, and the AutoX guys all love him.
    http://www.thealignmentguy.com/page3.htm
