Problems with tires or something else?
Discussion in 'Modifications And Maintenance' started by strangefamous, Aug 6, 2008.
  1. strangefamous
    OK. My buddy at work got 4 new tires from discount tires. After they were put on she drove them home and they started making this thumping sound. The faster she goes the faster it sounds. She took it back to discount tires where they took all 4 of them off and check the balance and all that. Then they took it out for a test drive and told her they were stumped. I am thinking maybe a bearing? What do you guys think? We are stumped!!! HELP!
  2. greg donovan
    it wasnt there before the new tires?
  3. strangefamous
    No. It was perfectly fine before the new tires.
  4. Scuba Steve
    did they miss up the wheels when they were mounting them???inspect the wheels and lug nuts
  5. strangefamous
    I did. I checked everything. The weights are fine... everything looks good. They even said they are stumped. I dont know what else to do.
  6. manochromatic
    manochromatic Member
    got mine done at discount as well and had the same noise (99 25rs) went back..they put plastic rings between the hub and rim and bam it was better!
  7. AWDimprezaL
    lol @ "even the discount tire guys are stumped"
  8. strangefamous
    They actually took the hubcaps off when they did the test drive and it was still doing it. THIS SUCKS!
  9. strangefamous
    Also, when they put the car on the lift...they started it up and put it in drive and gave it some gas. Only 1 wheel was spinning and then the second one finally started spinning with it. Could this be an issue?
  10. ShortytheFirefighter
    No, that sounds normal for an open diff. I'm assuming this is probably a FWD car? As far as the tires making noise, the only thing I can think of is they were slightly out of round from being stored. A lot of places store tires vertically rather than on their sidewalls and with the weather being as warm and humid as it is sometimes they'll settle a bit and take a bit of driving before they go back to round.
  11. strangefamous
    Ok cool. Discount tires said they will put 4 new tires on her car to see if it improves. He is shipping the tires from their warehouse which is a temp controlled building so we will see. thanks for the help.
  12. gc8
    gc8 Well-Known Member
    Aftermarket wheels? The plastic ring was a hubcentric ring.
  13. greg donovan
    are they 100% sure the lugnuts are tight enough?
  14. DGRx
    DGRx Member
  15. strangefamous
    You were 100% correct! The sound is gone and they are working fine! Thanks guys.
  16. strangefamous
    UGH. The sound is back and it is worse. Thinking it isnt the tires anymore. Wheel bearing? any input? Take a shotgun to it?
  17. greg donovan
    wheelbearing wouldnt come and go.
    i hate to beat a dead horse but have the lugnuts been checked? if they are alloy wheels they need to be retourqed after about 100 miles.
  18. Paul Revere
    Discount has always hooked me up, I hope you get this figured you.
  19. strangefamous
    No, she hasnt had them retorqued. I will let her know that she needs to have that done.
  20. greg donovan
    that is the only thing i can think of that would be gone and then come back a few days later. and since the noise wasnt there before it would have to be related to something with the wheels and tires.
  21. strangefamous
    Ok, thanks for the info. She went in this morning to get the wrenched on. I guess we will see.
