Prodrive 3-Port Boost Control Solenoid
Discussion in 'Modifications And Maintenance' started by jdm4you, Apr 13, 2009.
  1. jdm4you
    jdm4you New Member
  2. predavore
    predavore Well-Known Member
    Why not Grimmspeed? Straight bolt in.
  3. Paul Revere
    And the fittings aren't plastic ...
  4. jdm4you
    jdm4you New Member
    Prodrives were the only other ones I had seen. Were can I pick one of the Grimmspeed ones up at?
  5. carl
    get the grimmspeed one
  6. Bullwinkle
    Pretty much all the 3-port solenoids are the same in terms of action (it's a very simple solenoid). Someone recently mentioned that you could still get the GM solenoid from gmpartsdirect, although I'm not sure if that's true or not.
    And yeah, Grimmspeeds solenoid is a very good one.
  7. jdm4you
    jdm4you New Member
    Grimmspeed it is then. Is there any were/shops in the cities that sell them?
  8. bobafett04wrx
    bobafett04wrx New Member
    +1 for grimmspeed
  9. predavore
  10. Bullwinkle
    They're local, too. Look in the shops section for directions to their shop. You can also PM them on the boards here, too.
  11. Soupboy
    Soupboy Well-Known Member
  12. jdm4you
    jdm4you New Member
    He just pm'd me so I'm going to stop by there and pick one up:banana:
