Prototyping v2: Real Phenolic Spacers!!
Discussion in 'Modifications And Maintenance' started by Justin, Mar 27, 2007.
  1. Justin
    Justin Well-Known Member
    do you know if the all the models have the same mani/tgv gasket layout? i thought i read somewhere that the RS's both old and new have the same layout.
  2. curly2k3
    i thought they did, but i am not sure to be honest... erik or someone has got to know
  3. Justin
    does anyone know where i can get an extra long thermo coupler??? i got one and its to short to reach into the car if i want to get the temp of the intake mani.
  4. Xcelor8
    Xcelor8 Well-Known Member
    Ya know, I have access to a thermo imaging camera, anytime I want to use one.... May be aweful helpful in proving a lot of heat claims...
  5. Justin
    now that would be fun to play with.
  6. AWDimprezaL
    nope not the same, different across the board, 1.8 2.2 and DOHC are the same 2.5 SOHC are different, i think phaze 2 2.2s are the same as the 2.5 SOHC
  7. Justin
    so to get this straight...
    1.8 = 2.2 phase 1 = DOHC
    2.5 SOHC = 2.2 phase 2
  8. AWDimprezaL
    as far as i know
  9. Back Road Runner
    Yeah, I would assume similar issues as with the TBS. You'll need to find different test beds to get sizing, or at the very least, get all gasket types from Subaru to make templates for each size and series of motor.
    With people wanting a thicker spacer and with even the concerns over stipping with your current spacer, you might consider selling the kit with extended bolts just to keep everything safe as well as allow you to test/run different spacer thicknesses, not only for thermal isolation but also its effect on the powerband from extending the intake track length. It's something to think about anyways.
  10. Justin
    yeah i agree. i need to do extensive testing regarding the stock bolt lengths and that mani/tgv spacers. anyone know of a hardware manufacturer??:)
  11. Dynapar
    thats idling temp. i wonder what the motor gets up to well its getting pounded, ya know like pounded to the point where the exhuast manifold is GLOWING. thats what really matters.
    i would also be down for testing product on phase 1 2.2l.
  12. Justin
    negative...we rev'd it real high on the freeway and the higest it got was after we beat on it and let it sit for a second.
    there is a max temp feature on the thermocoupler and we had it reading the entire time..idllng, beating on it, etc
  13. mnstilynwrx
    mnstilynwrx Well-Known Member
    so know what your good to go? start production?
  14. Justin
    i ordered a few sets for testing purposes that will be here in 2 weeks. once those testers confirm everything is mint then i'll order a ton.
  15. mnstilynwrx
    cool sounds like a plan hope everything works
  16. Justin
    a couple pics. one showing it on the car...they are the same layout as the gasket so it will match up perfectly. another showing that there are enough threads left to tighten it down nicely.
  17. curly2k3
    yeah i have the 2.2 SOHC... if your making them at all i am game to buy/ test
  18. Xcelor8
    It really is, took it around my house and winter, tells you right where drafts are, let me know if you want to get together one day and play around with it, It's my brother's camera.
  19. Justin
    here are some pics from our first shipment. thanks to evan for taking these..
  20. Dream
    That's a nice looking manifold and tgv's :cool:
  21. curly2k3
    so how much are they gunna run?
  22. Justin
    i'm thinking 59.99 for the spacers
    and 9.50/set of Subaru OEM gaskets(encouraged to use new gaskets)
  23. Nuke
    not bad deal
    how about with install? if....? :biggrin:
  24. Justin
    install is going to be more cause its a longer process. we can definitely work out something so we can install them for you guys though.
  25. Speedemon
    Speedemon Well-Known Member
    what are you talking about? that one looks like ****
  26. readymix
    Where's my set Justin?
  27. Justin
    well i figured you didnt want to TEST a set on the dyno.
  28. LSE Performance
    LSE Performance New Member
    Test them on the dyno!!
    Which grade of phenolic is this? I have a spacer on the stealth, works great for keeping the intake manifold somewhat manageable to the touch. NO gaskets needed in my case.
  29. Justin
    CE phenolic. we can definitely test them on the dyno once we know what the best way to install them is
  30. curly2k3
    as stated last night at FS, i will be buying a set :)
  31. piddster
    I'll say they look tizzight. Looked them over today when I was at Grimm's.
  32. Justin
    yes cup
