questions on timing
Discussion in 'Modifications And Maintenance' started by ikpthegame, Jul 31, 2010.
  1. ikpthegame
    ikpthegame Well-Known Member
    So last year when Nuke tuned my car we were having timing issues. What all plays a role in the timing? Cause right now the only timing advance I'm getting is from knock correction.
  2. AWDimprezaL
    gas, air intake temp, air fuel ratio, load, mechanical issues that the knock sensor may pick up. (if you have a built motor with bad piston slap, you may not be able to run as much timing because of the noises the knock sensor picks up)
  3. Bullwinkle
    Everything has an effect on timing. Answering your question is like trying to answer "What has an affect on the weather?"
    Assuming you are using RomRaider, knock correction is basically logging the timing advance table. Logging the knock correction parameter will give you your timing advance value unless the car is currently pulling timing due to a knock event or a learned correction.
  4. ikpthegame
    So if logging that tells me the timing advance, how do I log knocks? And yes I'm using romraider.
  5. Bullwinkle
    Feedback correction (timing pulled from current knock events)
    Fine learning correction (timing pulled from previous knock events)
  6. ikpthegame
    ok thanks, once i get my oil line fixed ill go log again and take a look at those.
