quick question about brakes.
Discussion in 'DIY Instructables' started by nickspence, Oct 24, 2013.
  1. nickspence
    nickspence Member
    I have an 03 wrx. the bolt pattern is 5x100. I purchased a set of 06-07 calipers,pads, etc but need a full set of rotors. Ive been told that the fronts dont matter but ill need 06-07 rear rotors. So I figured ill buy a complete set of 06-07 rotors, but found out the bolt pattern on 06-07's is 5x114 which wont fit.. my question is which year rotors should i buy? i think im going to order a set from these guys... http://www.adamsrotors.com/
  2. Ntxhuav_Khang
    Only the sti are 5x114. Wrx are still 5x100.
  3. TMF
    04 sti is 5x100 ;)
    Ntxhuav_Khang likes this.
  4. nickspence
    nickspence Member
    sweet, thanks for clearing that up!
  5. Ntxhuav_Khang
    Lol thanks for the correction. I knew that too. Lmao
  6. boone1186
    boone1186 Active Member
    Where did you buy the 06-07 calipers from?
  7. blackozone
    What year/make/model are the calipers from that you bought? If you bought STI calipers, that needs to be addressed.
    Providing all the information possible helps with people with knowledge being able to guide you correctly.
  8. Ctracey218
    To help clear this up..
    He purchased my 06/07 wrx brake upgrade.
    SS lines, bbk rear adapters, and of course the calipers with pads.
  9. boone1186
    Will 2010 WRX OEM sized rotors work with this caliper upgrade?
  10. JasonoJordan
    So then why is he not just getting the 06-07 roters that match the brake calipers rather then asking what years cross over?.
  11. blackozone
    He bought STI rotors, which will not fit.
    OP, get 06/07 WRX rotors all around. You should be fine with that.
    Shane86 likes this.
  12. Kevin Harrington
    Kevin Harrington Member
    Did you get the normal 06 07 calipers or did you get the limited calipers, which is the red 4 pot 2 pots.
  13. Kevin Harrington
    If you did get the red ones I know frozen rotors has power slot slotted cryo treated rotors. And I believe they give an mnsubaru discount
  14. gc8
    gc8 Well-Known Member
    I believe all '06-'07 WRXs came with the red 4/2 pot calipers.
    boone1186 and GregRoot198521 like this.
  15. 06TR
    06TR Member
    yup
