Quick question before I get pissed!
Discussion in 'Modifications And Maintenance' started by Ninjaplease!, Nov 6, 2008.
  1. Ninjaplease!
    Rochester
    So, I just picked up my 09 last saturday. Monday morning, I was showing a buddy of mine the car, and he had mentioned that he had never seen a horizontally opposed 4cyl before. So I pop the hood to show him, and he says "well, wheres the turbo?"
    As I am pointing out the turbo, I noticed some discoloration on the flange. As I look closer, it appears to be rust. RUST ON MY BRAND NEW, 2 DAY OLD TURBO. So i start to freak, and I figure, before I jump to conclusions, and head up to dealership and make a big scene, I was just curious to ask....
    Is there any type of coating they put on the engine parts that would make it look like this? or any other reason the turbo would appear rusted, even though it is not?
    thanks,
    Bob
  2. readymix
    Eloh, El
    rust on the hot side is normal. And pretty much any turbo you buy, even brand new, has surface rust coloration. For reference, I have a GT2871R sitting in my basement. It has never been on a car and is wrapped in plastic still. It has some surface rust on the hotside. Nothing to worry about dude.
  3. Snowbum
    Snowbum Well-Known Member
    Mound
    Does the 09 not have a heatshield?
  4. readymix
    Eloh, El
    Even with the heat shield you can still see some of the hotside poking out.
  5. Snowbum
    Mound
    ohh okay :)
  6. Ninjaplease!
    Rochester
    Gracias :)
    I am new to the turbo world, and have never seen rust on a turbo before.
  7. ej20
    ej20 Well-Known Member
    I'd say its normal.
  8. Chux
    Independence, MN
    yea, has to do with the type of steel they use.....or something. it's cast, very thick, and probably not galvanized. it's normal.
  9. Ej22TIM
    Ej22TIM Well-Known Member
    MNSubaru B-Series Member #713
    looks like they sold you a used turbo.
  10. Snowbum
    Mound
    ^ lol, dont get the guy worried here tim.....but no seriously it's not going to last, you should prolly throw a 35r rotated assembly kit on there :)
  11. sneefy
    sneefy Well-Known Member
    If there was a galvanizing coating, it would just burn off anyway.
    They have to use a good steel that can take the stresses of heating and cooling to such wide temperature extremes and not crack under its own stress. Stainless, for example would be too brittle and it would crack in no time.
    The thin coating of rust won't hurt it. Don't worry about it.
  12. piddster
    Boostonia
    Stainless actually works very well, and you can use less material. The trouble is, it is much more expensive, and more difficult to work with. Look at how many downpipes have cast stainless bellmouths, and TiAL has stainless steel turbine housings.
    Stainless steel stays in its austenitic phase all the way up to the melting point, unlike cast iron and other various steels.
  13. hella_sti
    hella_sti Well-Known Member
    that is unacceptable! Take it back right away and trade it in for an srt-4!!
  14. Impreza 2.2 T AWD
    Impreza 2.2 T AWD New Member
    Avondale!!!
    hopefully when you were buying the car the dealer told you to keep the car running for a minute if you were driving it hard.
  15. Tim the Plumber
    Bloomington
    dont for get break in period!
    PS Hella, your avatar is SMOKIN!
  16. greg donovan
    Fargo
    iron+heat+moisture=rust
  17. subytek
    subytek Well-Known Member
    Further west than Ted.
    You do not have too.
  18. wall of tvs
    dream ftw
    Congrats for not being one of "those guys." :laugh: ;)
  19. AWDimprezaL
    Monticello.
    liquid cooled turbos dont need this, although it wont hurt.
