Readymix EJ22T build thread...
Discussion in 'Modifications And Maintenance' started by readymix, Dec 17, 2006.
  1. 02blubru
    So jason, what is going on with? do you have a new motor? If so what? When you putting it back together??
    phi11 likes this.
  2. readymix
    Not sure yet, I'm broke. The PPGs pretty much killed any spare money I had :(
    phi11 likes this.
  3. readymix
    Blah blah blah. You know what happened. EJ257 w/ Mahle's swapped in. Hit the dyno. Fueling issues.
    Car was running fine up to 5750rpms, then the AFRs would skyrocket to 12.5:1. Even after Clark took the gardenhose approach and set the Injector duty cycle to 97% to compensate for it.
    One of the techs at LSE and myself sort of agreed that it was likely the fuel pressure regulator. I picked one up from MTKA Morries Subaru the other day and finally got around to swapping it out.
    Short answer, yes, I think it fixed it. Tom will have to log AFRs to confirm, but I think I'm in the clear. Before swapping the FPR, I would get a knocklite flash at 6000rpms @ WOT. Now I can roll it out to 7000rpms with no knocklight indications. This is a good sign. Too afraid to stare at my rearview to see if there was black smoke from running super rich or not, but I'm assuming I spit something black out the back end. We will check AFR tomorrow to see what happens. Clark said he'd have no problem altering my map accordingly.
    Bad news though, it appears my Koyo radiator is leaking at the petcock. I need to pull it off and wrap it in teflon tape or something. I'm hoping that is where the leak is and not a crack in the welds (unlikely). Once the car cools down I'm going to give that a go.
    phi11 likes this.
  4. fobiawrx
    fobiawrx Fabiola
    do you have a knock off like dreams? a koyorad?
  5. readymix
    ??? What the hell are you trying to say ??? That makes no sense. I have a Koyo Radiator. Says Koyo on the top of it.
    phi11 likes this.
  6. Sogonerg
    Sogonerg Anteater
    I had my petcock leak'in and we just tightened it...We just unbolted the subframe to get it from underneathe...Pull'in the whole radiator just plain suck...
  7. readymix
    I wouldn't pull the whole radiator, I'd likely just have someone plug the hole with their thumb while I wrap the petcock in teflon tape, then toss it back on there. I'd probably lose less than a gallon of coolant in the process that way. Otherwise, I can jack the car up on the passenger side to slosh as much coolant as possible away from the hole. I have the petcock as hand tight as I can get it, I may take a pair of needle nose and try turning it some more, but the petcock is plastic, so I don't want to wrench it off or break it in the process of doing this.
    phi11 likes this.
  8. readymix
    Checked the petcock, gave it a little 1/4 turn with the pliers. Leak fixed. Now it needs a bath ;)
    And one of my downpipe bolts fell out again :( Those things are a pain in the ass to find.
    phi11 likes this.
  9. fobiawrx
    fobiawrx Fabiola
    v-band ftw!
  10. wall of tvs
    Agreed. However, purchasing a new turbine housing FTL.
    And Jason, quit using those stupid allen bolts. Just get some real hex bolts that you can actually torque down.
  11. Shane86
    Shane86 Well-Known Member
    High-Temp Locktite
  12. Dream
    dont make me fight you. koyorad is the new design for 07, so mine is better than yours :p
  13. readymix
    Now I have misfires from 3k-4k WOT in 4th gear. Not sure if this is a over-fueling misfire though or not. I'm going to have Tom log AFRs tonight. I'm thinking the misfires might be caused by the increased fuel flow causing things to run too rich. But I could be wrong on that one. It feels kinda sluggish, so who knows.
    phi11 likes this.
  14. wall of tvs
    Yeah, you can get rich misfires. Take it easy on the car until Clark sends you a new updated map -- you don't want to wash down the cylinder walls and have bad things happen.
    phi11 likes this.
  15. readymix
    Agreed. I'll see you down at the stonez. We'll get to the bottom of this business.
    phi11 likes this.
  16. tangledupinblu
    QFT!
    phi11 likes this.
  17. phi11
    I was trying to find photos here. It looks like the photos didn't transfer well.
  18. curly2k3
    sadface
  19. derp
    ppg's suck.
  20. readymix
    Yes, if you're a meat fisted goon, you will wreck a PPG gearset.
    derp and tangledupinblu like this.
  21. tangledupinblu
    That's why it is imperative to "cull the wheat from the chaff...CULL THE WHEAT FROM THE CHAAAAAAFF!!"
  22. AWDimprezaL
    BUT WHAT POWER LEVEL?
  23. readymix
  24. Aegis
    It's really ****ed up that I was talking about this build at work just a few days ago and here's the thread about it
  25. AWDimprezaL
    IN THE FUTURE THE PAST HAS ACCURED
    readymix, tangledupinblu and Aegis like this.
  26. curly2k3
    This thread makes me want to pet my barnacle.
  27. readymix
    I was in the future, it was too late to RSVP.
  28. tangledupinblu
    Is it possible for me to get a ride in this thing when it’s done?
    readymix and Aegis like this.
  29. Aegis
    I have nothing to add.[​IMG]
  30. tangledupinblu
    It’s science!
  31. retreif
    Looked like it was really done in that craigslist post.
  32. readymix
    Aegis likes this.
  33. tangledupinblu
    Maybe I could take it to HIN when you button up the punch list?
    This thread is educational!
    Aegis likes this.
  34. readymix
    Nhibbs and curly2k3 like this.
  35. tangledupinblu
    I can relate to the btw.
  36. tangledupinblu
    FTW-furry toilet wookie
  37. AWDimprezaL
    penis is stored above the balls.
  38. Aegis
    ^a very astute observation
  39. AWDimprezaL
    OLD THREADS ARE STORED IN MY FEELS
  40. tangledupinblu
    Is this car done yet?
  41. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    Oh wow, there's a blast from the past. Bet you're kicking yourself for fawning over those clearly inferior PPG gearsets in hindsight eh?
    Nhibbs and tangledupinblu like this.
  42. curly2k3
    PPG gearsets distract from the glory that is the best BOV sounds.
  43. tangledupinblu
    BOV=Black Out Valve?
  44. curly2k3
    if you accelerate hard enough, yes, you'll black out.
  45. Nhibbs
    Nhibbs Well-Known Member
    Didn't some noob end up buying this car and trashing it? I forget the story now it was so damn long ago.
