Readymix EJ22T build thread...
Discussion in 'Modifications And Maintenance' started by readymix, Dec 17, 2006.
  1. piddster
    subyti in da taddy ta
    A little bird told me that baby will be runnin soon.:biggthumpup:
  2. readymix
    VF34 is sold already, pending payment from Aspitfire. And the NeoGens are ok, not the best tires I've owned, but they work.
  3. readymix
    Ray is going to have the PPGs to me on Friday. Cams and everything should be here today. UTEC probably tomorrow.
    Hopefully Brian can get the gears in that case by next weekend. If so, I'm looking to fire the car up for the first time on Sunday of next weekend!!!
  4. AWDimprezaL
    zomg hot
  5. tangledupinblu
    :woot: :woot: :woot: :woot: :woot: :woot: :woot: :woot: :woot: What more is there to say!?
  6. 02blubru
    when is the smoke test party?
  7. readymix
    Probably have that at the same time. Might need a few sets of eyes to check for leaks etc. Bring your flashlights. I'll post a date in the Events Section when I know for sure. There was a mixup with the fuel pumps, so those wont be here till next week probably.
  8. Se7enrex
    Se7enrex Well-Known Member
    updates???
  9. readymix
    Updates. I'm not sure Sunday is going to work out now. There is just far too much to do in very little time. A week to get this done and all the parts are still lying all over my basement floor.
    Brian is coming over tonight, I spoke with Mike Wray about piston/valve clearance a bit. I'm going to try a few things and see what we can come up with. With any luck, everything will check out and we'll have the block and heads fully assembled this evening. And likely the smaller stuff like intake manifold and exhaust manifold/uppipe, clutch and flywheel.
    The transmission will leave tonight with Brian along with the PPG gears and other tranny bits. Hopefully they can get assembled in a week during Brian's down time at work. I don't see it being too much of a problem, but you never know.
    But with the magnitude of the jobs left to do, I just don't see how we can jam that into a weeks time. I also still have to wire in the DTEC and the UTEC, solder in the stuff for the UR injectors....blah, there is just way too much to do in 7 days. But i'll know more as the week comes to a close how things are going. I want it done, but I don't want to rush either. I waited this long so I want to make sure it's finished off right.
  10. piddster
    ^word. You definately don't want to rush something you have so much time and money in.
  11. readymix
    Agreed. I figure one extra week will slow the roll a bit, and give me time to make sure everything is clean and neat and done right. And it still gives me a few weeks to put some miles on it to break in the motor before Clark gets here.
  12. AWDimprezaL
    ^^ you can practice doing the lap of the twin cities @ the speed limit
  13. readymix
    No freeway driving, mostly in town stop and go.
  14. AWDimprezaL
    all you have to do is vary your rpm, but yes, around town for the better
  15. readymix
    I could see possibly doing the one lap during the noon hour, or possibly around 7 after traffic dies down a bit, that way there are people on the roads to slow down and speed up for.
  16. readymix
    Here's some pics of today's progress. We got the heads bolted up to the block. Still need 3 buckets to get the lash right. But those will be here next weekend, and it gives me time to finish painting the valve covers.
    There is a crank case breather elbow that had to get yanked. Brian is going to cut it off and fill it with JBWeld so I can use it as a plug instead.
    There is a snag on the intake manifold. The fuel lines don't clear the turbo, lol. Everything is just too damn big. So I'm going to have to run the rails in reverse which means I'm probably going to have to disassemble the rails and flip them around so the lines can sit properly. This will just take some extra time out of my life, but whatever works. Once I get that figured out, I have to wire in the new low impedance injector controller box into the engine wiring harness. Just 8 wires to solder so no big deal.
    The tranny is still sitting at MTKA awaiting word from AndrewTech as to where the shim he sent me is supposed to fit into the thing. We just can't seem to figure that out. Once we know, Brian has to press the gears onto the main shaft and re-assemble the transmission [​IMG]
    The key to today's progress was in the piston to valve clearance. It will work fine. So we are 100% good to go.
    So, on to the pics.
  17. TRUBLU
    TRUBLU New Member
    ok, how the hell are you allowed to bring an engine into the kitchen? My wife goes ballistic if I take anymore then one step int here with muddy shoes.
  18. StatGSR
    StatGSR Well-Known Member
    ^ looks great jason!!!
  19. tangledupinblu
    Hahaa, you tell her it's her new "center island!":laugh:
    Sexiest center island evar btw!:biggrin:
  20. Nuke
    you eat, sleep, sh1t, do everything, subie
  21. readymix
    Easy. Get a divorce.
    Then find a chick that doesn't mind an engine in the kitchen. And also, one that likes to take pictures of engine blocks in the kitchen. ;)
  22. Dizmal
    Dizmal Well-Known Member
    Haha, gold reverse intake manifold. Nice. Straight up gengsta!:yumyum:
  23. Speedemon
    Speedemon Well-Known Member
    looking good!
  24. AWDimprezaL
    brian does good work! cant wait to see it
  25. fobiawrx
    fobiawrx Fabiola
    getting close! cant wate to see it up and running!
  26. piddster
    These motors can be touchy when it comes to PCV. Be careful.
    Ididn't show up at uni cause I've been orking on my AFPR setup, which has a snag, but dammmit, I wanna get dirty. Plus I have the fastest toolbox around ;)
  27. readymix
    The WRX only has the one on the top of the block...the EJ22T has two. Now if I was going to use the EJ22T heads and ECu, I'd probably worry about it. But since I'm using the WRX heads and ECU I'm not too concerned about crankcase breathing. The EJ20 doesn't have it, so neither will mine. I don't forsee it being an issue. But definately much thanks for pointing that out.
  28. wall of tvs
    sooooo hot.
    I'm calling a preemptive permanant shotgun when riding in this. :p
  29. readymix
    BTW, we ran into a small snag here. Nothing major, but still a problem. There is no possible way for me to get a filter/intake whatever on the inlet of that turbo. The fuel rails stick way out due to the UR injectors and the fuel rail lines are also slightly in the way.
  30. wall of tvs
    hmmmm.....that's a sticky wicket
  31. fobiawrx
    fobiawrx Fabiola
    bet i can make somthing to fit....
  32. esperunit
    esperunit Well-Known Member
    just throw some panty hose on there and don't ever go on a dirt road =]
  33. readymix
    But I have to go on a dirt road...because all Subaru owners are rally drivers...ALL OF THEM.
  34. TRUBLU
    TRUBLU New Member
    Panty hose on turbo inlet = Dose Pipe
    hahaha
  35. readymix
    Here's a pic of what i'm talking about...
  36. TRUBLU
    TRUBLU New Member
    uh-oh...
    any plans or overcoming it without redesigning the exhaust?
  37. TRUBLU
    TRUBLU New Member
    I just remembered that a buddy had similar issues with a car. He ended up using a motorcycle filter. The issue is finding the right one with a big enough opening. (obviously)
    He didn't seem to have any issues with flow from it either.
  38. readymix
    Another option might be finding a silicone coupler with a slight bend in it and putting a filter on that way.
  39. Steve in Minnesota
    Steve in Minnesota Well-Known Member
    Any such thing as a 90 degree fitting(s) coming out of the fuel rail and have run the fuel lines into that eliminating the big bend? I'm clueless but it seems logical.
    Steve
  40. esperunit
    Can the fuel lines be lengthened to a point where they can be moved more?
    I think a silicone hose would work, but it would be a tight fit and abrade against the fuel lines, probably crapping out the hose after a while. Is the a 90degree fitting that can but put at the joint where the fuel line meets the fuel rail maybe?
  41. readymix
    This is also another option. If necessary, I may take these things to that Aeroquip truck and have them hack and splice in some 90 degree fittings. The only problem with this idea is that the rail itself is still in the way, regardless of where the lines are going. There might be more room to come up with a solution, but it doesn't ultimately solve the problem.
  42. piddster
    What kind of fitting is that on the end of the rail? It doesn't look like a standard AN.
    From the pics, it looks like 45 degree hose ends would give you some more room to work with at least.
  43. readymix
    Fobia stopped by and we flipped them around. I'm going to have to have some hoses made to go from the distribution block to the feed and return.
  44. RicerSube69
    RicerSube69 New Member
    looks good, gl
  45. Dynapar
    i would get some 90* AN fittings, and route them straight down. then curve up and in with the stainless lines. it could give you the clearance you need to fit a coupler or intake on there.
    otherwise take you DP, and make it go bendy bendy alitle bit and you will clear no problem.
