Readymix EJ22T build thread...
Discussion in 'Modifications And Maintenance' started by readymix, Dec 17, 2006.
  1. readymix
    Removing the fuel lines from the rails is near impossible, and will likely destroy the lines themselves anyway. The best bet we've come up with will be to extend the lines to and from the distribution block a few inches to reach the spot where they were originally designed to be. They are easy to remove, and simple to replace. Fobia will likely weld up a short aluminum pipe that can connect to the turbo inlet and accomodate a filter.
  2. readymix
    So now it turns out that AndrewTech sent me a 4th gear sprocket instead of a 3rd gear sprocket...they are overnighting me one, so hopefully that fixes that problem. I'm quickly running out of time.
  3. wall of tvs
    that's cool that they'll be able to overnight the part at least
  4. Sogonerg
    Sogonerg Anteater
    Sorry Jason...
  5. readymix
    Not your problem bud, don't worry about it, you didn't pack the box. AndrewTech took responsibility for it right away and owned up to the mistake. And agreed to make right by overnighting me the gear I needed.
  6. tangledupinblu
    That's good business! Glad to here it's not going to set you back too much!;)
  7. readymix
    yeah, they're great vendors for sure. They've overnighted me two parts now free of charge. I definately can look past the mistakes when they make that much effort to fix them. Definately a stand up bunch of guys. And Andrew is one of the easiest guys to talk to. Often times I have to cut that guy short so we don't run the phone call on for half an hour talking about non-business stuff.
  8. readymix
    Well, with a little bit of engineering, and alot of fried chicken, it seems the valve lash is finally where it's supposed to be. We had to rig up a press with a grinding wheel and actually re-size the buckets ourselves. Subaru no longer makes shimless buckets smaller than 469, so if your valve lash measurements tell you you need something smaller, give driftin240 a call ;). A few loud grinding noises and a couple micrometer checks later and we had the heads fully assembled.
    The PPG 3rd gear I was missing just arrived. So we're set to go on that. I'm taking it to MTKA today with me along with my oil pan (hot tank ftw) and with any luck, the tranny and engine will be resting in the car once again tonight :)
  9. Sogonerg
    Sogonerg Anteater
    kewl kewl...let me know how those PPGs turn out...dammit mine should have been installed first
  10. readymix
    I'll let you know. I should have them done today and back in the car tonight.
  11. Sogonerg
    Sogonerg Anteater
    with your car being setup and my exterior mods being done...it should be combined into 1 silver REX...haha
    I wonder if we could somehow mold the 2 rex together..!?! hmmm
  12. readymix
    I'm fine with that as long as you keep your lambo doors.
  13. curly2k3
    so is it possibly going to make a uni appearence tonight if all goes smoothly?
  14. wall of tvs
    I seriously doubt it as there's a ton of aux stuff that needs to be bolted up and wired after the engine & gearbox go in.
  15. readymix
    yeah, I doubt I'm going to have the car running this weekend, that would be a stretch. Likely have it running next weekend. I have alot of piping, vaccum, oil, coolant lines etc... to cut. Plus my fuel distribution block feed and return lines don't even reach the filter.
  16. fobiawrx
    fobiawrx Fabiola
    pics of it in the car please!
  17. Justin
    Justin Well-Known Member
    i just got back from there. block is in the car.
    i have some interesting pics of petes block
  18. fobiawrx
    fobiawrx Fabiola
    so post them!
  19. Justin
    i'm to tired and lazy right now.
    long story short there was a pool of coolant sitting in his driver side intake valves
  20. fobiawrx
    fobiawrx Fabiola
    pics would help......
  21. Justin
    only if you crinkle the tb
  22. readymix
    Pics coming...Fobia, you got your work cut out for you bud ;)
  23. fobiawrx
    fobiawrx Fabiola
    need gas and we are good to go... but pics first
  24. readymix
    Previous post now has pics. Clearance Clarance? Srsly, we need that Aeroquip truck now....power steering lines FTL. And I've now given up the creature comfort of cruise control.
  25. piddster
    Is it really that in-the-way?
    Oh, I've got about 6ft extra -6 line if that helps.
  26. fobiawrx
    fobiawrx Fabiola
    apc filter! nice!
  27. fobiawrx
    fobiawrx Fabiola
    should of put the wireing harness and got all that crap done before you droped that thing in. might scratch the paint now! looks good
  28. fobiawrx
    fobiawrx Fabiola
    might be able to switch the rails back around now with that filter?
  29. fobiawrx
    fobiawrx Fabiola
    posting up this thread! boyakasha!
  30. readymix
    The paint scratching isn't an issue, it can easily be touched up if necessary.
    The power steering lines absolutely must be re-routed...they just wont work sitting next to the turbo, you'd have to see it up close to understand, but the intercooler piping wont be easily routed if it is in the way...and it rubs the filter.
    As for the other side of the intercooler, I'm going to have to hack off some of the fan shrouds on the radiator...there is just no room for a pipe in there...the Koyo is just enormous. Again, Fobia, you'll just have to come over and see it in person.
    That's just a start, I'm sure more snags will present themselves this week.
  31. readymix
    Actually, the way the lines are now, is fine. I don't mind it. And getting two new lines made to mate up with the feed/return isn't really a big deal IMO.
  32. fobiawrx
    fobiawrx Fabiola
    maybe tomarrow after all the girls fam stuff i can stop over and look?
  33. fobiawrx
    fobiawrx Fabiola
    bit if they work the right way then no line will have to be made.......
  34. readymix
    yeah, call me tomorrow, I'll be in teh garage most of the afternoon I'm sure. Come check it out and we can brainstorm a bit.
  35. readymix
    Actually man, now more than ever the lines wont fit the 'correct' way. The way they are now, the filter is around half an inch from the fuel rail...that would leave no room for the fuel lines coming out of them. We can try, but I'm thinking that wont happen.
    When you stop by today, bring your angle grinder ;) I got some things that need to be chopped off.
  36. readymix
    Also, you can kinda see in this picture where things are a bit 'close'
  37. fobiawrx
    fobiawrx Fabiola
    ok i will see what time i get done with the girls fam stuff and then i will call you.
  38. readymix
    Ok, sounds good man. Later is not an issue, I'll be out in the garage for a good portion of the day.
  39. readymix
    Is this braided steel line? I may actually be able to use that!
    I believe that is what the fuel rails use.
  40. Dizmal
    Dizmal Well-Known Member
    I never would have thought to go with gold, but it looks like hard nipples to me.
    Looking damn good, sucks about the cc. I don't know if I could live without it.
    <---- big cruise control whore
  41. TSTRBOY2004
    fixed that
  42. RichWRX
    RichWRX Well-Known Member
    It suks not having cruise control, I dont have it either
  43. curly2k3
    i can honestly say i NEVER use my cruise in the SVX or the Impreza, and i love the gold!
  44. Dizmal
    Yah, when I get drunk. I have easy written all over my forhead;);)
  45. Justin
    my L cruise have never worked....when you are on the gas ALL of the time it doesnt matte. stop being a poooosay
