Readymix EJ22T build thread...
Discussion in 'Modifications And Maintenance' started by readymix, Dec 17, 2006.
  1. readymix
    So close!
    I need to stop by Menards and grab a bolt for the starter, we tapped the hole last night so it should be all set to go on that front.
    I need coolant hose for the turbo.
    I need an oil return hose for the turbo also.
    The biggest issue I have right now is the alternator secondary bracket with the adjustment on it. For some reason it sits about a 1/16th of an inch too far forward and it placing the alternator pulley out of alignment, which could cause the belt to slip off. It isn't off by much at all, but it is enough to worry. Fobia is stopping by to have a look and see if he can use his artwork to fix it up.
    I need one more pipe welded for the IC piping.
    And I need to rewire the MAF sensor wire.
    Aside from that stuff, the typical stuff:
    Oil
    coolant
    tranny fluid
    UTEC map upload
    Unmarry the AP (yes, I know you are waiting for my AccessPort ;))
    That pretty much covers it, barring any issues with the alternator bracket, I might be able to fire this biatch up before Friday :) Time to prepare the neighbors for a 20 minute, 2000rpm cam break-in, lol.
  2. tangledupinblu
    w00t! So close you can almost taste the exhaust!:yumyum:
    phi11 likes this.
  3. AWDimprezaL
    awesome
    phi11 likes this.
  4. wall of tvs
    h00ray!!!!!!!!!!
  5. readymix
    Tom, I may need you to do an Enginuity flash to get it to idle right. Not sure yet. Do you think you could help me out with that this week?
  6. wall of tvs
    Yuppers, can do. I'd just need to know the correct size of the tube that the MAF sits in.
    Didn't Clark send you a ROM for that, or was it just the UTEC file?
  7. readymix
    Just a UTEC file. The tube is probably 2.5". Which will likely cause all sorts of issues if you tune it for MAF useage on any sort of throttle, but this is mainly for idle, I believe the UTEC takes over after that and runs based on MAP. We'll have to see when I load up the map on the UTEC.
  8. Dynapar
    wow thats is really close to being ready. when are you going to fire it up? i wanna see this beast.
  9. w_o_t_boy
    w_o_t_boy Well-Known Member
    You'll just do the standard injector scaling adjustment like we do with every other car, right?
    So what do you do with the MAF scaling table? Multiply everything by (3^2)/(2.5^2)?
  10. wall of tvs
    Well I guess we'll have to see how that works, lol. I'm not sure what exactly triggers the CL --> OL crossover. Do you still have all of those jackass steps in right around the MAF sensor?
    Jason -- can you contact UR and get me the correct latency values for your injectors? I can't seem to find them anywhere online.
  11. wall of tvs
    A good starting point with the MAF would be to multiply the g/s tables by a constant represented as [(new MAF ID)/(stock MAF ID)]. So with a 2.5" MAF tube, the correct scalar should be about 0.9549.
    But we need the correct injector latency values first before anything else.
  12. Dynapar
    make sure to take some video of the first start up.
  13. readymix
    Nope, the jackass steps are gone, had the MAF plate welded directly to the IC piping. I'll see what I can do about the latency values for the injectors.
  14. curly2k3
    its sooo close, i cant wait to see this thing around firestone again
    phi11 likes this.
  15. readymix
    Well, with any luck, it might be at Firestone on Friday. But don't take that as a for sure yet.
    But that is my goal. I'd love to have it out this weekend to cruise around in.
  16. wall of tvs
    Perfect!
    If we can get those latency values, we'll be golden.
  17. readymix
    I'll call UR and see what I can find
  18. readymix
    6v - 2550 uSec
    7v - 2550 uSec
    8v - 2080 uSec
    9v - 1620 uSec
    10v - 1300 uSec
    11v - 1050 uSec
    12v - 880 uSec
    13v - 750 uSec
    14v - 650 uSec
    15v - 570 uSec
    16v - 510 uSec
  19. AWDimprezaL
    if that thing doesnt run tonight you are a fool get wiring basicly
  20. readymix
    Workin' on it
  21. Dream
    gold ftw
  22. AspitFire
    awesome, cant wait to see this thing run
  23. fobiawrx
    fobiawrx Fabiola
    did the alt and pipes work out good?
  24. Steve-o
    Not sure if this helps but on 785cc UR injectors this is pretty damn close for the latency table:
    6.5 9.0 11.5 14.0 16.0
    2.55 1.74 1.31 0.76 0.55
    The numbers on top are the battery voltage.
    Nevermind... I see jason already posted them :eek:
  25. readymix
    IC piping fits perfectly. The Alternator...not so much. Still cocked even after re-drilling it. I'm gonna leave it for now just to get it running. It isn't off by that much. But I will have to fix it before the tune.
  26. Dynapar
    sweet. so the filter is stuck right onto the turbo? talk about shortram. also i did not see a duck call on the RFL
  27. readymix
    Another thought I had was to notch the holes on the Alternator bracket so it can be rotated a bit. Then get a lock washer and crank down on the thing.
  28. readymix
    No more duck calls, it was fun, but it doesn't fit well on teh RFL and I don't need any restrictions on the venting of pressure ;)
  29. fobiawrx
    fobiawrx Fabiola
    did you re-drill it in the brcket to get it to the right spot?
  30. readymix
    Yes, I redrilled it in the bracket but for some reason it still ended up just as cocked as it was before. You should stop by today if you get a chance and look at it. I might try firing it up tonight as long as I can get teh oil and coolant hoses made for the turbo.
  31. fobiawrx
    fobiawrx Fabiola
    call you after work and see what happens
  32. AWDimprezaL
    it better run tonight.
  33. readymix
    Come over, we'll try.
    I ran into another small hurdle that will likely be fixed before you even get here tonight. The coolant return from the head is pointed directly at the turbo outlet. I'm sure that bolt that holds the tube isn't required though, so I'll just undo it and cock the pipe to fit. It's not really an issue, just another hold up.
  34. readymix
    And Fobia, you didn't call me after work you jackass.
  35. wall of tvs
    you said cock
    phi11 likes this.
  36. readymix
    If you saw the tube I'm talking about, you'd understand why.
  37. wall of tvs
    that's offensive......just like defeats I will suffer from you on the racetrack this summer
  38. readymix
    You comin' over on Saturday? Erik seems to feel it will be running tonight, but I doubt it. Possibly tomorrow.
  39. wall of tvs
    Yeah, I can probably make it over on Sat. I emailed that break in map to Brian, btw.
  40. readymix
    kthx. I don't think I'll be firing it up tonight though. Odds are I'd rather wait till you were there to play with the tuning and use the wideband and such.
  41. AWDimprezaL
    you will fire it up with the break in map, i doubt brain wants to come over two times since hes putting a t belt in bills car sat
  42. readymix
    Well, then get your ass over here with haste and lets get this thing on the ground.
  43. readymix
    The Franken-block has laid waste to our villages and people and all our...craps.
  44. Aegis
    "Crops" is what I wrote.
    Your car is like *beavis grin* right now. You better get it running, or it may decide never to run again ... :hsugh:
  45. Shibbs
    Wow. I need to see this thing. Need yet another hand?
    Oh, and I've had my fair share of alternator troubles on my old car. Fiero GT FTL.
