rear diff leak(?)
Discussion in 'Modifications And Maintenance' started by 054eatwagon, Jul 17, 2009.
  1. 054eatwagon
    054eatwagon Well-Known Member
    when i put on my catback the other day Tony pointed out that my rear diff was dirty/oily
    i am guessing i will need to look into it further , what parts would be involved , just a gasket/gear oil? is this something that would be easy to do , drain fluid...take off cover...install new gasket.....refill??
    any help or suggestions would be great
    and there is a pic in the members rides thread that shows the rear diff of my car from the other day if that helps
  2. bobafett04wrx
    bobafett04wrx New Member
    You should get a better picture its pretty dark, I can see its oily or wet looking but its hard to what all is wet or where it came from.
  3. AWDimprezaL
    Its a plugged vent tube on top, its making it over-flow.
  4. 054eatwagon
    so do i need to just remove the vent tube and clean it out ? if so i should be able to handle that
  5. AWDimprezaL
    You clean it from the inside of the diff, so you remove the upper plug and start cleanin.
  6. 054eatwagon
    thanks , i will try to do it tommorow
  7. Chux
    yea, depends where it's leaking. if it's just a clogged vent, that's fairly easy. or if the rear cover is leaking, also pretty easy.
    the side seals mean the axles have to come off....which is a large project. not terribly difficult, but a lot of stuff has to come apart.
    if it's the input seal. it's a bit simpler than the sides, but the nut that holds the input flange on is torqued on there very tight. so it's a PITA to get off, and at least as difficult to get torqued back down properly (and it's crucial that it does, as it's an integral part in the gear mesh. I did one and didn't get that nut tight enough, and it screwed up the gears in the diff....).
  8. 054eatwagon
    my plans are clean outside , check what was mentioned , and see what it looks like in a week or so , if its bigger then the vent i will be looking for someone to do this one for me
  9. tonyM
    My drive way is open, let me know!
  10. 054eatwagon
    pressure washed it tonight and will check it in the morning
    thanks
