rear disc brakes?
Discussion in 'Modifications And Maintenance' started by Clu7ch, Nov 3, 2008.
  1. Clu7ch
    Clu7ch New Member
    alright question i hav a 96 brighton coupe and origanally has drums in the rear... i hav the rotors and wrx calipers brake lines etc. but is there some type of conversion bracket or piece i can buy? because judging by the way the hub is set up there is no way they'd bolt on with out somthin else.... anyone done it before or any input? thanx
  2. prezawagon
    prezawagon Well-Known Member
    You really need to change the rear knuckles to those from a disc brake subaru. The backing plate is different between drum and disc, that's what the caliper mounts to. You'll also need the ebrake parts for each side. It's possible to switch the backing plate/ebrake without changing the knuckle, but you have to pull the hub to do it and that means putting in new bearings seals, etc...
    You can see the rear knuckles with the ebrake still attached (the rotors are off and hubs are pulled out), on the left side of this photo. I'm in the (slow) process of converting my rear drum to disc.
  3. Clu7ch
    Clu7ch New Member
    dang... i was hopin it would be easier... my drums and shoes are good now i inspected them but i got the calipers and stuff with the car so i thought it would hav been more simple... well looks like this is movin way back on my to do list...
  4. Ej22TIM
    Ej22TIM Well-Known Member
    im parting out my legacy, you can buy the entire disc brake setup.
  5. manochromatic
    manochromatic Member
    those look familiar joel!!! still havent got them in yet? whats the hold up...it looks like alot of work to do this swap tho.
  6. Clu7ch
    Clu7ch New Member
    i might take u up on that tim did u stil want the injectors cause id love the IC or w'e ur willin to give me for them lol
  7. Clu7ch
    Clu7ch New Member
    pm sent
