Rear Speakers
Discussion in 'Modifications And Maintenance' started by Mekhem, Mar 5, 2010.
  1. Mekhem
    Mekhem Well-Known Member
    So after the thread earlier this week about the OEM sub I noticed that I was not getting any sound out of the Sub and rear speakers.
    This afternoon I went in to check the fuse on the sub harness and to check the connections. The fuse was ok, I reconnected everything.
    Now I have sound out of the Sub and left rear but nothing out of the Right Rear.
    Any Ideas?
  2. errorcode3
    errorcode3 Member
    are they stock speakers? because i would be looking for a loose wire someplace, since thats the most likely culprit. check both where they get the sound input, amp or cd player (i don't know what you're running) and and the speaker itself.
    edit: and if you are running an amp then you have a little more work, checking rca's, grounds, even a loose screw in the amp can make it not work.
  3. webcrawlr
    webcrawlr Well-Known Member
    Funny you post this. My OEM head unit would stop playing sound out of the right front speaker every now and then. A good smack on the side of the center console fixed it right up though. Something was loose somewhere..
  4. errorcode3
    errorcode3 Member
    it could be a connection getting pinched, and pushing the connector off kilter. But at least on mine the stock speakers the connector is this cheap plastic/ceramic thing that breaks super easy, i put some bags in the trunk and just them shaking back and forth broke the connector dealy.
