Recommendation please :)
Discussion in 'Modifications And Maintenance' started by strangefamous, Aug 27, 2008.
  1. strangefamous
    What are you thoughts for an air filter for my stock airbox?
  2. Nuke
    stock paper
  3. ArcticWolf
    ArcticWolf Well-Known Member
    stock filter
  4. strangefamous
    Roger that. No high flow filter?
  5. Scuba Steve
    yeah, the diffrence between my oiled K&N high flow and a stock paper filter is about 75whp.:eek3:
    na...kidding, it's like .00000005 increase in horsepower at higher rpms....maybe. plus the extra cost in buying one for 35+ dollars AND having to clean it.
    go stock
  6. Nuke
    You can
    The Perrin foam one worked great, but was greasier than a fry cook's face.
    The K&N one was nice too, no problems with that, but when cleaning, remember not to oil it too much.
    I had both of those but now I have an intake
  7. strangefamous
    Sounds good! Slappin that bad boy back on and using the injen cold air for and ice scraper for my driveway this winter :p
  8. zyklon
    zyklon Well-Known Member
    Not to mention that the K&N's are proven to remove less particles from the air. Which is, of course, the purpose of having an air filter in the first place.
    Full test results here:
    http://duramax-diesel.com/spicer/index.htm
  9. silver03
    Avo make a product for WRX? I have one on my Legacy.
  10. Vector
    Vector Rally Organizer
    Amen.
    Foam filters are the worst.
    Oiled cotton gauze (ala K&N) are a close second worst. I have one on my rallycross car, but only because I had to redo the setup to get the air intake up high. The stock air intake on a B13 Sentra could hardly have been better designed to scoop up water. Funny thig is, a SR20DE with a cracked block, cracked head, one shattered connecting rod and a bunch of bent valves will actually still run! (from personal experience)
