recommended Wheel bearing brands
Discussion in 'Modifications And Maintenance' started by MNSnoDrifter, Jun 26, 2011.
  1. MNSnoDrifter
    I was looking at Rockauto to order some new wheel bearings and was wondering if anyone had some input, If one brand is better than another.
    thanks
  2. JasonoJordan
    im running oem they have worked good so far n with the discount they are not to expensive
  3. G_2.5rs
    G_2.5rs Well-Known Member
    i got rockauto's wheel bearing for mine and it still works great after a year. forgot which brand though.
  4. Munky King
    Munky King Well-Known Member
    This is a job I'm about to do. Where are you getting the old bearings pressed out?
    I was thinking of seeing if I could buy a new hub with bearings already in place for my 01 RS to save the hassle - especially as the hubs can also be scored. Any info greatly appreciated :)
  5. readymix
    My guess is you wont find a full assembly like that. At least not from an OEM.
  6. Threshld1
    Threshld1 Well-Known Member
  7. Munky King
  8. MNSnoDrifter
    I have someone to do them for me at the dealership I work at. I thought I saw a post a while back talking about a good bearing to go with, but I can't find the post...that's why I was asking.
  9. MNSnoDrifter
    ok was just checking on Rockauto for bearings and other things, I noticed that there are 2 different SKF front inner and outer seals listed, that have different dimensions. how do I know which one I need?
  10. Chux
    There are really only a couple companies that make bearings, so the quality of the product doesn't vary much.
    Shouldn't be any variation in the seals....that doesn't make any sense.
  11. AWDimprezaL
    Fronts have an inner and and outer seal, rears have an inner, an inner inner, and and outer.
  12. MNSnoDrifter
    yeah Ive read that on NASIOC but when I just looked at parts from rockauto they listed 2 different inner ones for the front that were the same brand, I guess the only thing that was different was the Width dimension on the seal one is .296 and the other is .315, is that gonna matter the OD, Shaft, and Bore sizes are the same....yeah also checked my driver wheel for play...yeah its totally shot
