Repair Project on 1995 Subaru Impreza 2.2L
Discussion in 'Modifications And Maintenance' started by Michael48, Jun 17, 2009.
  1. Michael48
    Michael48 Member
    Restoration Project on 1995 Subaru Impreza 2.2L
    My brother crashed his car two days ago. I'll post pictures soon.
    The car has 89K, new tires, AWD, and a automatic transmission
    So Far/Parts needed:
    Hood (is a pyramid)
    Radiator (A/C Maybe? might not want to fix, How do I close of the A/C line if I'm not using it anymore?)
    Driver side Head Light
    Driver side fender
    Battery and entire brackets assembly + base
    The part of the car that the fender is attached to is pushed in 12"+
    (Weld it? what is the best way to fix so the new fender has something to bolt to on the front?)
    The timing belt cover is cracked and has a 2" hole in it.
    (Can I just epoxy it or should I replace the cover?)
    I will post more as I find more stuff needed to fix. I'm trying to fix this car for cheap!
  2. Shane86
    Shane86 Well-Known Member
    Replace the cover.
    but defenelty check the belt, and all the timing. if it got wacked and skipped a tooth, it could have bad repercussions.
  3. piddster
    Don't you mean repair? To restore the car would most likely mean several thousand dollars worth of factory sheetmetal, if you want to actually restore the car.
    You want something for the fender to bolt to? Buy the sheetmetal to replace it properly, or pay someone some money for a decent amount of time on a framerack. Or get creative with a hammer, bench vice, and a welder.
  4. piddster
    It is a '95 2.2. They can contact valves on a non-interference motor, but it is really really hard.
  5. Michael48
    Michael48 Member
    Yes I should of wrote "REPAIR". Can you see the shape of the rear end of a pickup across the hood? Here are some pictures.....
  6. Michael48
    Michael48 Member
    My brother started and drove the car a block after the acident, It ran just fine he said.
    I'll replace the timing belt cover.
    The metal work I think I'll weld? or replaceIt seems like it a large single piece that the fender and headlights bolt too. Should I just get un bent section cut out of a junker and weld them in place of the bent and torn metal on my car?
  7. piddster
    You could do that.
    Get out a tape measure and start comparing distances. For instance, each strut toer to the opposite corner, and so on. There is a good chance with a hit that does that much damage things aren't straight anymore.
    You'll need an upper core support as well. The center support could be salvaged. It's going to to be some work though. I wonder how the end of the frame rail looks.
  8. Michael48
    Michael48 Member
    From what I can tell the frame rail end is what the bummer attaches two Luckly the truck was high enough that it went over the top of the bumper and frame end the bummer is attached too. I'll post more pictures as I make progress. I really don't think anything bent as far as alignment and frame goes just the sub body of the car (if thats what its called) where the head light, front fender, and top of the radiator are mounted too.
  9. Warthog
    Warthog Member
    The biggest worry there is that the strut tower may have gotten tweaked at a new angle. If your looking for junkyard parts try car-part.com you will find ANYTHING you need.
  10. Michael48
    Michael48 Member
    Thank you ^ I'll check it out!
  11. Colin
    Colin Well-Known Member
    I have every single part on your "parts i need" list, and will sell them all gladly.
  12. Michael48
    Michael48 Member
    PM Sent^
  13. Michael48
    Michael48 Member
    Here are some picture updates and a picture for Colin on my A/C radiator connections!
  14. Michael48
    Michael48 Member
    Colin owns it now, Lets see it finished! :biggrin: Have a good 4th Colin!
  15. jmailhot
    jmailhot New Member
    good luck with this project bro!
