Replacing brake fluid with hi-temp
Discussion in 'Modifications And Maintenance' started by asujosh1, Mar 25, 2009.
  1. asujosh1
    asujosh1 Member
    I am planning on replacing the DOT3 brake fluid in the STi with some DOT4 hi-temp stuff, anyone know the capacity of the 08 STi braking system?
    Also, what order the wheels need to be bled in to ensure that I get all of the older fluid out?
  2. Iroc-Z
    Iroc-Z Well-Known Member
    Start with the furthest wheel from the master cylinder. If you don't let the master go dry you shouldn't have any problems.
  3. carl
    not sure if the 08's are the same but on my 04 the left rear is the farthest from the bmc
  4. Shibbs
    Get plenty, about half a gallon just to be sure. You can always return what you don't need.
  5. asujosh1
    asujosh1 Member
    Half a gallon??!! Seriously? I was thinking 2L!
    oh, wait....... 2L = .5Gal..... :biggrin:
  6. twofiveRS
    twofiveRS Well-Known Member
    I can't speak for the sti but the 2.5rs has a funny bleeding proceedure. not the typical start from the furthest wheel. I'd try and look into it more. .02
  7. WRX1
    I did my wrx and I did the GF's lgt when I replaced the lines and everything and I didn't use much more than .5 pint. I KNOW for a FACT that I replace all the fluid since I used ate super blue.:biggrin:
  8. Scuba Steve
  9. carl
    yea we re-ran all the lines (hardlines and softlines) on my car and didn't use an entire bottle filling the system
  10. Shibbs
    Yes, .5 gallon was kinda high, I know. But you never know if there will be complications. :)
  11. twofiveRS
    ^Thats what I was alluding to. Does that apply to all subarus?
    I <3 super blue, although I've been questioned at two track events about why my fluid is dark.:biggrin:
  12. carl
    does what apply to all subarus? complications? lol
  13. twofiveRS
    LOL, edited for fast posters
  14. TSTRBOY2004
    you have to remember the brake lines are small, the most fluid you have is in the reservoir itself... so buy a cheap turkey baster, suck it down till there is only a small amount left in it.. top it off with new stuff and bleed... at tops you would need 2 qt size bottles... and that would depend on how many times you bleed from each bleeder...
  15. asujosh1
    asujosh1 Member
    Thanks for the info. That link provided exactly what I was looking for in the bleed order.
    I am also replacing the stock for the blue, so I believe that it will be pretty obvious when I get to the new fluid. It's just too bad that I can't put steel braided lines on the car, this would be a perfect opportunity...
  16. redheat86
    redheat86 Well-Known Member
    Does anyone sell ATE or Motul locally?
    Also I do not want to deal with so does anyone want make some money that has done this before?
  17. Paul Revere
  18. asujosh1
    asujosh1 Member
    That's where I am getting my ATE from, provided they can get some stock before the weekend.
  19. blake
    blake Well-Known Member
    I bought some Motul from them last summer since they were out of Super Blue forever. Good stuff, works amazingly well. Brakes feel a thousand times better, much firmer pedal, no more sponginess. Although, I gotta admit I've never actually used the Super Blue brake fluid.
  20. WRX1
    Frozen Rotors down in Burnsville has it on hand, and they give us a discount.
  21. asujosh1
    asujosh1 Member
    I'll check with them, Adam says he can't get it for the weekend.
