rims and tire
Discussion in 'Modifications And Maintenance' started by jing123, Mar 8, 2008.
  1. jing123
    jing123 Well-Known Member
    anyone know wat size rim and depth plus tire will not rub on a gc8 with stock suspension i wanna get i guess one of the bigger size such as 18x8 with a good size tire thanks
  2. The Giraffe
    The Giraffe New Member
    i personaly run 245/40-17 on a 17X8 but if you dont plan on rolling fenders or putting 3mm spacers in the rear then i wouldn't go more then a 215/40-18 or a 215/45-18 on a 18x8 rim. anything more then a 215 typically rubs depending on your suspension mods for the gc8... rolling your fenders makes a BIG difference
  3. jing123
    alright thanks i'll look into that but is the 17x8 pretty good size for the gc8
  4. The Giraffe
    IMO i think 17's are as big as you should go so that you can still have a sidewall to absorb all the bumps and potholes of minnesota roads. so yeah i like 17x8 the only problem you might run into is your rear tires rubbing on the strut hence the need for a 3mm spacer in the rear. here is my car on 17x8's
  5. hakstern
    hakstern Member
    17*8 ftw. On my gc8, im running the same (245 tire width) but with ssr. I like them and feel more grip compared to my cousin 17*7.5(215 tire width). Both the same tires.
  6. jing123
    alright thanks alot i guess 17x 8 it is with some spacers
  7. jing123
    but just in case anyone know where i can roll my fenders
  8. The Giraffe
    Minnetonka Autobody did an Amazing job on mine i would highly recommend them.
  9. hakstern
    hakstern Member
    Colin.
  10. FuJi K
    I run 17x8 +48mm 235/40/17 Falken Azenis RT615.
    I RUB during hard cornering. I had to roll the fenders. I think it would clear the stock struts, but not the fenders.
    For stock suspension or coil spring/strut setup, I'd say 215/45/17 on 17x7 / 17x7.5 wheels.
  11. jing123
    will checkl up on that thanks
