salt in carpet from winter
Discussion in 'Modifications And Maintenance' started by trek44, Apr 27, 2008.
  1. trek44
    trek44 Active Member
    Anyone have a tried and true easy way to clean the salt out of the carpet from the winter slush?
    Thanks
  2. RallyNavvie
    RallyNavvie Well-Known Member
    Take them out and use a carpet cleaner. If you mean the "carpet" built into the car then just use repeated cleaning with water to dissolve it and soak it up with rags. The carpet is so synthetic that salt isn't going to hurt it much. You run more risk of it going bad by letting organic stuff rot in the carpet. I picked up the heavy duty rubber floormats for my LGT when I first bought and used those all winter to avoid the salt and junk that snow would track in.
  3. trek44
    thanks
  4. Chin
    Chin Well-Known Member
    SubieDave! (Stanley Steemer)
  5. pbedroske
    pbedroske Well-Known Member
    take it to a do-it-yourself carwash - use the pressure washer soap on them! squeegie out the water with a snow brush/scraper - leave out in the sun to dry.
  6. Taras
    Taras BANNED
    this! works great! mine look brand new now.
  7. Soupboy
    Soupboy Well-Known Member
    I use Weathershield mats (really foot-well tubs) for this reason in the winter. Carpet stays unmolested.
