Scary engine clicking noise
Discussion in 'Modifications And Maintenance' started by mathshop, Nov 13, 2019.
  1. mathshop
    mathshop Active Member
    Minnesota
    Anyone knows what this sound might be? It's from a 2012 wrx? Car doesnt boost when this happens but sometimes goes away randomly.
    Mods are catless downpipe, intake, uppipe, ebc controller and forge bpv.
    Thanks in advance!
  2. tangledupinblu
    MNBugeyeMafia#001
    Who tuned it? Or are you running an AP?
  3. mathshop
    Minnesota
    It was tuned by JM.
  4. Cotts612
    Cotts612 Well-Known Member
    That 2nd video sounds like a loose heat shield.
  5. mathshop
    Minnesota
    The heat shield is loose, but in the first video you can see me holding on the the heat shield, so I dont think that it. :(
  6. mathshop
    Minnesota
    I've looked at a few videos and it sounds similar to some of what they're thinking which is lifter tick and exhaust manifold leak, but not sure.
  7. Jerf
    Jerf Well-Known Member
    Jerfbury
    My first thought was lifter tick.
  8. minnesotanice
    Stillwater
    Is it coming specifically from the turbo? If you aren't getting boost while the noise is there, it may be a stuck open waste gate actuator? Just throwing something at the wall.
  9. mathshop
    Minnesota
    It sounds like it, but I still hear it at idle.
    Would you still expect to hear this noise when idle?
  10. minnesotanice
    Stillwater
    Not sure. I'm just thinking out loud saying this so take it with a grain of salt, but maybe the noise is the waste gate stuck open and the actuator trying to close it?
    *Edit* Listening back to the videos I don't think this is the issue.
  11. mathshop
    Minnesota
    Alright all I took it into RS and they said it was the wastegate actuator. So now yall know :)
    Thanks for the help!
