Registration: http://www.motorsportreg.com/events...ce-county-fairground-scca-land-o-lakes-711971 Join us as we continue the 2016 RallyCross Season in the Spring Fever RallyCross event held at the Rice County Fairgrounds. This venue is in Faribault and holds up well with plenty of area to go fast and throw lots of dirt around. Come out and play in the dirt with us! Sign up by midnight on Sunday May 15th, and receive a $5 discount off the normal registration fee! First timer rallycrossers: please read through this Quick Reference Guide to understand some key safety rules. Want more information about SCCA Land O' Lakes region RallyCross events, check out ourwebsite (www.scca-racing.com/gorallycross). Click "Continue" below to register! Not sure you want to compete yet? Come out to watch and see what it's all about, spectating is free, everyone just needs to sign a waiver when you get there. Schedule: 8:00 a.m. - 9:00 a.m. Registration 8:30 a.m. - 9:30 a.m. Tech Inspection 9:30 a.m. Drivers Meeting 10:00 a.m. Runs begin ~ 12:00 p.m. Lunch ~ 4:00 p.m. Wrap-up meeting and awards LOCATION: Rice County Fairgrounds 1814 2nd Avenue NW Faribault, 55021 Requirements: All competitors must have a valid driver's license. Helmets are required for all participants and passengers. Helmet must meet the latest or two immediately preceding Snell Foundation Standards (SA2015, SAH2015, SA2010, SAH2010, SA2005, SA2000, M2015, M2010, M2005, M2000, K2015, K2010, K2005), SFI standards 31.1, 41.1, 31.1A, 31.2A, 41.1A, 41.2A or British spec BS6658-85 type A/FR are acceptable. ALL COMPETITORS MUST BRING A WORKING FRS RADIO FOR USE DURING THE EVENT! FRS radios cannot be shared between competitors. All competitors must be either full SCCA members or buy a weekend membership. All competitors are required to work the course as a condition of their entry. RULES: All competitors and spectators must sign the official SCCA Waiver of Liability. All minors present must have a minor waiver filled out. Form can be downloaded, printed in color and filled here: click here All competitors MUST work the course as a condition of event entry. All competitors must have an FRS Radio, radios cannot be shared between competitors. All competitors must have a Snell/M2000 or newer helmet. Loaner helmets are available but the quantity is limited. Passengers will be allowed if waivered and wearing an approved helmet. See official rules here: http://www.scca.com/pages/rallycross-cars-and-rules Cars will be checked for the following items, please make sure your car passes all the listed items before the event. ·All loose items, inside and outside the car (including the trunk and storage areas) removed ·Snap on hub caps and other detachable accessories (e.g. fender skirts, trim rings) removed ·Convertible, targa or t top vehicles must have their factory hard top panels securely in place ·Lug nuts tight, correctly installed, none missing ·Tires in good condition (no cords or belts showing, no cracks, etc.) ·Seat belt(s) present and properly attached ·Positive throttle return ·No excessive leaks (engine running) ·No “spinner knobs” ·Brakes in proper working order ·Wheel bearings, steering and suspension in good working order ·Battery tightly secured, positive terminal insulated ·Helmet rated Snell SA2000/M2000 (or newer), BS 6658 85 type AF/R or SFI 31.1 ·Passed sound ·FRS Radio (we usually use channel 8-0) Classes are Stock, Prepared, and Modified and then each class is divided up into FWD, RWD, and AWD. See official rules for car classing.
