Se7enrex Full Build Thread "LOLCar" reincarnation
Discussion in 'Photo & Video Gallery' started by Se7enrex, Jul 20, 2014.
  1. Chux
    It's not terribly crucial which way they go, coolant flows through it....
    But, the lines do not cross from the factory. The top pipe on the engine is a bit more to the passenger side, it goes across to the passenger side on the firewall, and the other one stays on the driver's side.
  2. Se7enrex
    Se7enrex Well-Known Member
    That enough for me, thanks!!!!
    Ryan FailRad likes this.
  3. Se7enrex
    Bent all my front lines, rear lines done- these are the fronts- holy canoli that was a chore!
  4. Slowbaru
    Slowbaru New Member
    This build is insane. I hope you end up going with fender flares, that would be so sick
  5. Se7enrex
    image.jpg image.jpg image.jpg image.jpg Getting so close...
  6. Zombie
    Zombie Well-Known Member
    Looks like fun Will!
  7. tangledupinblu
    Flares flares flares!!!!!
  8. Ctracey218
    He bought a set of flares from me.. SO, I imagine it should happen! :thumbup:
    Ryan FailRad and tangledupinblu like this.
  9. tangledupinblu
    Likelikelikelikelikelikelikelike!
  10. Se7enrex
    Dun dun dah!!! image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg image.jpg
  11. tangledupinblu
    Ctracey218 likes this.
  12. Ryan FailRad
    This is a sweet project! I wish I had the ability to do something half as cool as this
  13. Se7enrex
    Before any body loses it - I DID weld the panels together and filled with seam sealer. Then when dry, I will POR 15 everything around there and respray well with undercoating. The front has been POR 15 (thus the black stuff.)
    GregRoot198521 and EricS like this.
  14. Se7enrex
    image.jpg image.jpg I'm a fan of element tuning
    EricS, TMF and MinnesotaFTW like this.
  15. EricS
    EricS Nooberator
    How long before it's going to hit the road, you think? :)
  16. Se7enrex
    Oh man- hopefully before July- getting close- just got back from Alaska -
    Now it's time to get to work... image.jpg image.jpg image.jpg image.jpg image.jpg
  17. tangledupinblu
    Alaska looks pretty dope Will-I-Am! So does all of the gold bling.
  18. derp
    Can I ask where you got the foil?
  19. Ryan FailRad
  20. souy07
    souy07 Well-Known Member
    Looking good...!!!
  21. Se7enrex
    And the over drain through the frame rail
  22. Se7enrex
    Looks like when we Began..... But now we are almost done- thanks to Jesse!! Wiring master! image.jpg image.jpg
    One major snag that I should have caught early on, when the harness runs through the fender it will absolutely get crushed by the wheel now that the fenders are cut and car is lower... Time to improvise
    I ended up pulling the fender brace and section it plus take a length of steel, cut to shape curve the ends, weld it, and create a new channel for the wires to ride on higher up and still allow drainage
  23. retreif
    Don't those fender braces provide some structural rigidity? Looks like your mod may hinder that. Nice project btw, I am always interested in your updates.
    Ctracey218 and Ryan FailRad like this.
  24. Se7enrex
    Yeah your probably right- but right now if it's easy to change down the road I'm going for getting the car running right now
    On a side note... I Need a Impreza tail light harness - it's 3 bulbs and a clip- anybody have one- - for the 93-2001 impreza chassis? I also need a cheap passenger seat to get me through tuning- pay nicely for either right now
  25. Ryan FailRad
  26. xluben
    How high can the coolant get in the washer reservoir before it's higher than the fill point on the radiator?
  27. 612-Automotive
    612-Automotive Vendor
    Se7enrex I have those parts if interested let me know.
  28. TMF
    I do have a Saabaru passenger seat (probably two even) that you could have for dirt cheap. The seat base is the same as the 02-07 wrx, and I believe those also fit in the GC chassis. Soonest I could get them to you would be on Sunday though. Let me know!
  29. Se7enrex
    About 3/4 way up.. But I still retained my oem header tank, so as an overflow I don't think it should matter as the tube goes all the way to the bottom of the tank and it works off suction or pressure, so if I keep the tank always above the tube and allow room for overflow it should be fine at any height I would imagine?!?
    I also actually did find a harness and seat from a buddy so we will see tomorrow what I end up with... Thanks everyone!! Initial test start is probably Wednesday this week!!!
  30. Ryan FailRad
    Just in time for the lax cruise! ;)
  31. Se7enrex
    Last stretch we test systems tonight! Maybe even a little start?
    And then at some point, maybe over winter or next year I want paint, and I'm thinking British racing green metallic- image.jpg image.jpg image.jpg
  32. Se7enrex
    I need help! Nuke came to tune- we flashed ecu , car will turn over but not start. This is an 05 sti harness with immobilizer , key, key drum, and ecu. But it's not getting spark or fuel---- though we hear fuel running through the lines... Need help? Anybody know how to bypass the immobilizer? Does anyone know definitively about needing a matching gauge cluster or needing the body integrated units installed to start the car?
  33. bikerboy
    Gauge cluster immobilizer code must match the immobilizer code in the ECU.
  34. Se7enrex
    Thank you, so I'm in a bind then... Shoot. What is the best way to get past this? I do not have access to the original gauge cluster... 04 sti ecu and repin harness connecter? Everyone tells me about the immobilizer bypass, but I can't seem to find any how to's. Bypass seems easiest? Any help is so appreciated!!!!
  35. bikerboy
    The proper gauges and all the keys programed at the dealer is the only way I know.
  36. EricS
    EricS Nooberator
    I'm pretty sure @Sjogun could get things reprogrammed to match, but you may have to tow the car to his shop - I doubt they'd let the programmer off the lot.
  37. Se7enrex
    So I have talked with a lot of people this morning- it sounds like I need an 05 cluster- any one, to work. Something with the fact that my 04 cluster is in conflict with my 05
  38. Se7enrex
    I'll pay someone $60 to let me test their 05 sti or 06 sti cluster for 5 min today
  39. EricS
    EricS Nooberator
    Throw a new thread up somewhere!
  40. bikerboy
    Some random cluster will not work either. The ECU and the gauge cluster both have to have matching RF ID tag info from the key programing for the immobilizer to be turned off.
  41. EricS
    EricS Nooberator
    So did you get it sorted out?
  42. MMC_555
    MMC_555 Well-Known Member
    Very cool build! I am jealous, wish I had the know how to tackle something like this :thumbup:
  43. Se7enrex
    It drives....kinda! Went to get some gas - rubs like crazy and is completely out of alignment and only a base tune but it RUNS (and vibrates a lot) :)
    IMG_0778.JPG IMG_0779.JPG IMG_0780.JPG IMG_0781.JPG IMG_0782.JPG IMG_0783.JPG IMG_0784.JPG IMG_0785.JPG
  44. EricS
    EricS Nooberator
    So awesome for you!
    what was stopping it from starting??!
  45. Se7enrex
    I think it was a mix of the immobilizer stuff/ some vacuum leaks / and a few wires that needed sorting - but she starts perfectly now every time - I ended up using an 04 ECU to help and that allowed me to ditch ALL of the immobilizer stuff
    souy07 and phi11 like this.
