Se7enrex's FMIC
Discussion in 'Photo & Video Gallery' started by w_o_t_boy, Jan 20, 2007.
  1. T-REX5000
    T-REX5000 Well-Known Member
    Are you running that setup on stock internals?
  2. bikerwriter
    bikerwriter Well-Known Member
    Mike, I didn't know you had it in you! That's a great install. You have definitely improved. You are no longer a grasshopper! :biggrin:
  3. AspitFire
    damn nice ported turbo! :)
  4. fobiawrx
    fobiawrx Fabiola
    it was the biggest pos so he switched it out with a perrin
  5. w_o_t_boy
    w_o_t_boy Well-Known Member
    I had a little help. I wish I had a welder.
  6. w_o_t_boy
    It was so squishy we were afraid if would collapse. We also wanted all the hose fittings that were in the Perrin box.
  7. Justin
    Justin Well-Known Member
    i guess i dont see how. it ran perfect on my hybrid set up.
  8. bikerwriter
    Is that car done yet? Or is Mike sleeping in today? :biggrin:
  9. Se7enrex
    Se7enrex Well-Known Member
    no mike and tom are getting up today even if its later hopefully so i can come over and we can finish it once and for all.:) but only after their hangover ceases to exist;)
  10. Justin
    i'll probably stop over and check it out today.
  11. wall of tvs
    no hangover for me, lol.
    Brian just showed up and we're gonna start in a few minutes.
  12. Se7enrex
    im headin out thers pretty soon, just need to find transportation i should be out there by 3:30-4, how long to get our tune done you thinkin??
  13. bikerwriter
    Get to work! ;)
  14. w_o_t_boy
    Well, it took forever to get the oil and coolant lines we fabricated to not leak, but its finally on the road. That BOV is noisey! Now it will slowly get faster over the next few weeks as Abe Froman works his tunezoring magic.
  15. T-REX5000
    sweet, you should show it off next saturday
  16. Se7enrex
    without a mother ****in doubt it will be there FTW!!!!!!!!!!!!!!!!:biggrin:
  17. Se7enrex
    BIG BIG BIG BIG BIG shout to Mike(w_o_t boy) for storage and muscles, Brian(driftn240) for the know how(not that the others didn't). Justin(justin) for parts-he will hook you up-buy his parts!!!, Fobiawrx for some quick welding and love of jagermiester, speeddemon for watching:biggrin: and providing good bike stories and last but fopr sure not least, Tom(wall of Tv's) for the insanely fast mapping and dedication---and cause he has to deal with me saying"FASTER" over the next months untill this thing flys, and yes the bov is awesome:biggrin: ...........you guys all rock and would love to do business with you anytime(just not with ebay parts).............
  18. w_o_t_boy
    Forced performance's web site says their oil feed lines have 10mm banjo bolts on one end and 12mm on the other just like the stock one. I think you need 12mm on both ends. You'd better call them and ask someone about that.
  19. shineynitelite
    damn those banjo bolts!!!
  20. shorty5198
    shorty5198 New Member
    holy s***!!!! That looks soooo tight!!! That engine bay is hot. cant wait to see the dyno numbers
  21. w_o_t_boy
    We hit 5.75 g of load on our safe map at only 14.3 psi if any of you know what that means. Now that we have an oil feed line on there that was made by a professional the thing is working well. Time to start slowly ramping up the boost.
  22. w_o_t_boy
    Don't forget getting Mobil 1 in my hair . . .
  23. bikerwriter
    5.75 at 14 psi? That's a good increase over 5 that I see at 17+ on the stocker. What MAF are you seeing? 275? 300?
  24. Dream
    When does this car go on the dyno?
  25. Se7enrex
    when the mobile 1 comes out of mike's hair:biggrin: , or when we think we got it dialed down, so fo sure by spring
  26. w_o_t_boy
    260 @5200rpm when we ran out of road in 3rd last night.
  27. w_o_t_boy
    After we port his uppipe. Its got a bit of a design flaw.
  28. w_o_t_boy
    Post pics with the hood closed, se7enwrx.
  29. tjamz
    tjamz Well-Known Member
    looking good Will!
  30. bikerwriter
    Which equates to about 260hp at the wheels. Nice. Now it's time to dial that turbo to 19 psi!
  31. Speedemon
    Speedemon Well-Known Member
    yah thanks, i dont know what you guys would have done if i was not there!
  32. wall of tvs
    Probably not until spring at the latest. I'm going to spend the next few weeks dialing it in after the GM bcs shows up. Until then we need to run a few tuning sessions on wastegate boost to smooth out those timing/fuel areas and to decide on a good boost curve to finally shoot for.
    After that, it's time to start on the demise of his transmission, hehehe.
  33. PimPreza_WRX
    speaking of transmissions, what kind of clutch is he running? do you know?
  34. w_o_t_boy
    A worn-out one.
  35. Se7enrex
    haha thats to say the least, but it still pulls hard, im the finesse master;) , oh and th egm boost solenoid will be here thursday(2maro), i fell in love with overnight shipping again:biggrin:
  36. mnstilynwrx
    mnstilynwrx Well-Known Member
    were did you order yours from. the only site i checked they were sold out. not to say there's no other sites. haha just being lazy....
  37. WRX1
    Hopefully you didn't pay to much. Alot of places relized that is the new subaru rage and doubled the price. I thin you should be able to normally get them for like $35 with the pigtail.
  38. wall of tvs
    Yeah, that's what rockauto is still selling for I think.
  39. bikerwriter
    I read somewhere that you need the GM BCS to maintain high boost levels, because the stock bleed-type bleeds off too much. Is there any truth to that?
  40. w_o_t_boy
    If you can't bleed enough air, the pressure to the wastegate actuator should rise, and you'll get less boost. 3-port solenoid also give you actual vacuum to the wastegate actuator when they're set the right way, helping hold the wastegate shut when you're trying to build boost.
    Will's problem was the restrictor pill wasn't opening his giant wastegate fast enough. That and he found some chunk of cotton stuck up against the pill that must've blown out of the compressor housing. Hmmmm.
  41. bikerwriter
    :laugh:
    But I will need the GM BCS at a later date to build and hold boost, correct?
  42. WRX1
    the gm is a blocking system and the stocker is a blead system. The gm will give you quicker spool up and a little bit better control. The stocker will would with most turbos, but once you get something other than a stock turbo you will probably want to change out the restrictor pill to maximize the efficiency. With the gm unit you don't need the pill. The stocker is a bit easier to tune, but more of a pain in the ass to set up. The gm is easy to set up, just more of a pain in the as to tune.
  43. shorty5198
    wow i just took a ride in his car last night and i have to say, when that EWG opens up it sounds like sex:eek:
