I have an 04 sti and when I bought the car it supposedly it had been open source tuned. I have recently changed the catback to another style with the same size pipe. Also i have added an cobb intake and have a silicone turbo inlet that i want to put on. My question is should i get a the car retuned after adding those 3 parts or can i install the silicone inlet and run the car the way it is without a retune?
After adding the intake yes get a retune or at least a log done to make sure the new intake hasent leaned the car out more then the intake that is currently installed.
ya im been tossing around the idea of getting a retune but was not sure if it made that much of a difference on the sti. But i figured with increased flow from the intake and the turbo inlet it would throw things off, so i just wanted to get some opinions. Thanks guys
Better intake/exhaust flow = faster spool = more air = lean = bad Granted, the mods your talking about would be a pretty small change.....but cost of tune < new motor
Shouldn't take that long at all. Mostly scaling for the intake change and verify and touch up full throttle.
