Slight coolant leak at top?
Discussion in 'Modifications And Maintenance' started by fdomestic, Nov 2, 2012.
  1. fdomestic
    fdomestic Member
    I have a GR Wrx and have noticed a slight leaking of coolant from what appears to be the metal T where the small hoses connect to at the top right side of the radiator, next to the coolant overflow tank. I noticed that there is a small dried stream of green that travels down the radiator fan. Coolant isn't bubbling. How do I stop the leak?
  2. issues
    issues Well-Known Member
    my 02 did this if I left the overflow tank empty it seemed to stop doing it.
  3. Nuke
    clamp?
  4. AWDimprezaL
    I imagine even a zip tie would fix it.
  5. Subie Lovers
    Drain the coolant and drive it that way
  6. fdomestic
    fdomestic Member
    I figure i would do this. Just wanted to make sure it wasnt anything scary.
