SlowTI, n/a ej257 going on dyno - guess the #'s and win!
Discussion in 'Modifications And Maintenance' started by carl, Mar 1, 2009.
  1. fondune
    115 aech-peez, 135 torques
  2. 9blackmax6
    122whp/135tq
  3. wall of tvs
    Agreed!
    A stock 227 hp (crank-rated) will put down around 170whp at RS, iirc. I think it is quite feasible to muster out 200hp (crank) out of a high compression 2.5L motor if you rev it high enough.
  4. kvang
    kvang Well-Known Member
    165whp, 195wtq.
  5. MrMcMonkey
    MrMcMonkey Well-Known Member
  6. Scuba Steve
    just got a text from carl, the car is now at RS!!! pray they work some majic. Who cares about power, I just want it to run properly!:)
  7. putz
    putz Well-Known Member
    sorry, I forgot all about the aftermaret pistons, yes.... in retrospect I am far too low in my final guess/answer.
    my spec-v w/ intake header and exhaust, 2.5 l put down 178 whp and 175 lbsfttq at the front wheels....
    so with drive line loss taken in to consideration, I would say I'm prolly still a touch low.
  8. Bullwinkle
    Hah, +1 to that. Tuning this thing well is going to be a feat in itself. :)
  9. sniper1rfa
    sniper1rfa New Member
    Yeah, but not on turbo cams/heads/exhaust.
    The exhaust is way too big and the cams won't be right.
  10. carl
    the exhaust actually is properly sized through the downpipe before opening up into 3"
  11. AWDimprezaL
    The cams will be the killer. BUT tuning with the avcs will be interesting.
  12. phi11
    2 dollars, bob.
  13. Shibbs
    No, 11:1 is NOT low compression. I think this will do better than most people think it will do. Plus, if Ronnie can manipulate the AVCS enough, it SHOULD do really well.
    I'm still hoping for 170 wheel hp.
    I think a shorter runner intake would definitely help alot tho.
  14. phi11
    damn, I was pwnd.
  15. Bielke55
    Sorry i waited for you to correct before i was gonna say something...
  16. idget
    :banana:
  17. phi11
    :disco:
  18. Chux
    yea, compression is definitely pretty high. which is why I threw out such a high tq number. although I hadn't thought about the cams.
    tuning for 92, though. hope they leave a safety margin there, as 92 is hard to get outside the cities.
  19. hella_sti
    hella_sti Well-Known Member
    can someone please explain to me the real theory behind this? non-turbo rally car and lowering the compression?!!?
  20. Scuba Steve
    no, higher compression (11:1) NON_TURBO motor so we can run the Open Light series this year in Rally America. Huge bump in compression!!!!
    we need to run an N/A motor until we get our coefficent points (18) and then step-up in class next year and get the turbo motor back in the car.
    it's the ONLY way we could use carl's car for rally america this year
  21. Shibbs
    Yes, stock compression is 8.2:1 or so. 8.2 -> 11 is a major jump. Most N/A cars are around 10:1 if that.
  22. tangledupinblu
    149hp/183wtq and a hott carl.
  23. Dynapar
    152hp / 189tq
  24. Ronnie@RSmotors
    Am I aloud to guess?
    You should all guess the power on the first run instead.
  25. Platinum Coan
    LOL
    So then... the results are in?
  26. Scuba Steve
    the official guess closure
    Carl asked me to inform everyone he's not taking any guesses after 330PM.
    I'm honestly suprised at the numbers....Carl will post when he gets home with the car. :)
  27. Scuba Steve
    yup, he is done:biggrin:
  28. AWDimprezaL
    I demand to know!
  29. readymix
    I see Carl lurking, post numbers or ban.
  30. piddster
    ^ Agreed
  31. Shibbs
    BAN HOTT CARL!!!1!one!!1
  32. wall of tvs
    agreed
  33. wall of tvs
    also, my bangun has a hair trigger
  34. AWDimprezaL
    My bangun has a trigger made of pubes.
  35. carl
    hey, I had to compile all the new guesses since I was gone - #'s are coming!
  36. wall of tvs
    just post the numbers, n00b
  37. boomer
    boomer Well-Known Member
    Still waiting.:(
  38. carl
    136/136 max
    Andrew (sniper1rfa) was closest by my method
    (hp guess - hp actual) + (tq guess - tq actual)
    closest to 0
    if putz hadn't changed his #'s he would have been almost nuts on
  39. carl
    Also, please note I made 48whp and 88wtq on the first pull haha
  40. wall of tvs
    48whp ftw!!!!!!!! lmao!
  41. sniper1rfa
    Yeah, the first run is those little dotted lines at the bottom.
    Also, my guess FTW :banana:
  42. AWDimprezaL
    lololololololol!
  43. AWDimprezaL
    Thats more then pete's RS, you are the MAN.
  44. readymix
    Flatline torque ftw
  45. Snowbum
    Snowbum Well-Known Member
    Very Niice!
