Spark Plugs
Discussion in 'Modifications And Maintenance' started by spoolem, Nov 18, 2009.
  1. spoolem
    spoolem Well-Known Member
    I have a 2003 WRX and I have it at stage 2 for mods right now. I was wondering what you guys/gals recommend for spark plugs? I have looked all over the forum and havent found a real good answer. It sounds like I should go with Copper no matter what sense they are most conductive and because I don't mind changing plugs often. Please give me you 2-cents worth! Thanks
  2. Deride
    Ngk vpower
  3. spoolem
    ^ Ya I was looking at the NGK PFR6G but I want to make sure that those are what I should be buying?
  4. Motorhead
    Motorhead Well-Known Member
    Stick with copper. This is the route I went after some research on here and NASIOC. One of the reputable members of this forum recommended NGK Copper so save your money and keep it simple.
  5. spoolem
    ^ Where should i get the copper spark plugs from and what's the brand? And by chance do you know what the model # is???
  6. Motorhead
  7. mnstilynwrx
    mnstilynwrx Well-Known Member
    I belive I have NGK's in mine as well. Stick with those
  8. Shibbs
    I know my car came with iridium, so I'm putting NGK iridium back in it. I've never had a problem with my OE plugs, why change what I know works? :dunno:
  9. spoolem
    Ok thanks for all of the input. Now that I have a better idea of what to get I will go buy some new plugs today :) Thanks
  10. john
    john Well-Known Member
    Stage 2 == stock plug, at least stock heat range.
  11. 96zj
    96zj New Member
