SPT intake
Discussion in 'Modifications And Maintenance' started by Blubaru04, Apr 7, 2008.
  1. Blubaru04
    Blubaru04 New Member
    I got a spt intake w/heat shield for my 04 sti. Installed it and reset ecu. Car starts and idle fine. The only problem I have with it is everytime I take the car to redline my i/c spray light flashes on then turns off when I let off. Does this happen to anyone who has a spt intake on? What cause the i/c spray light to come on?
  2. hella_sti
    hella_sti Well-Known Member
    check the area around the filter, it could be rubbing on a relay or plug causing a short
  3. badbennyb
    is your i/c tank low on water?
  4. Blubaru04
    No, I checked fluids. Still full.
  5. Dream
    That's odd, almost sounds like the jdm i/c spray switch is on your car....
  6. Blubaru04
    it's stange. I'm gonna log the car tomorrow to see if temp reading is ok
  7. wrexinator03
    wrexinator03 Banana Cream
    with the shortram your intake temps are gonna be higher but that shouldn't affect your ic sprayer tho
  8. webcrawlr
    webcrawlr Well-Known Member
    The only thing that switch does is keep the contacts closed. The light in the dash is a low fluid level light... unless there's something I don't know?
  9. Dream
    The jdm switch can be set to spray at certain rpm's, not sure if the light flashes or not. Just a thought...
  10. webcrawlr
    Not by itself. You need to have a boost pressure switch in the mix, too. I'm currently running a setup like this. No light but works great!
  11. Dream
  12. webcrawlr
    Yeah. I got the IC switch from them, boost switch from ebay. The JDM switch alone just keeps the contacts closed, like and on/off switch.
    Stock:
    http://www.bescaredracing.com/sti/intercooler/sprayer/auto/diagram/stock.JPG
    Using JDM switch and boost pressure switch:
    http://www.bescaredracing.com/sti/intercooler/sprayer/auto/diagram/togglejdm.JPG
    You can also simply replace the stock switch with the JDM version above. Same effect but you don't retain the spray on demand use.
  13. subynate
    subynate Well-Known Member
    how do you like your ic sprayer? its been a thought for me..
  14. webcrawlr
    I love it. It helped quite a bit in the summer months. I've got mine set to turn on around 7PSI so I tend to go through a tank of water every week. Sometimes more.
    Setup was easy, too. You can do it on the cheap with any 2-way switch if you don't want to get the JDM.
  15. Dream
    Just out of curiosity, what does your intercooler look like? Any hard water build up?
  16. webcrawlr
    I only fill with distilled or deionized so there's no worries about that.
  17. Dream
    So you just used filtered water from your house?
  18. webcrawlr
    I just buy 2 1/2 or 5 gallon jugs for convenience.
  19. Dream
    That must add up $$$$$
  20. webcrawlr
    I'd imagine I spend around a buck a week.
