Squeaking clutch
Discussion in 'Modifications And Maintenance' started by ChristianO, Jul 15, 2012.
  1. ChristianO
    ChristianO Member
    Alright clutch problems round 2. The car is a 2006 WRX with 110,00 miles, the clutch is an Exedy with about 4k on it.. only street driving. The problem is, when i step on the pedal i get a Squeak, can hear it from outside the car too. Secondly, when im driving and take it out of 5th gear then put it back in (clutch fully engaged), the gear grinds slightly. If anyone has any info i would love to hear it. thank you.
  2. mrantegra
    mrantegra Well-Known Member
    clutch master cylinder, had the same issue but for a different car.
  3. ChristianO
    ChristianO Member
    The cylinder itself is going out? ive read up on it a little and read that the bracket can break and squeak, but im not really sure. The sound comes from below the intercooler (top mount).
  4. mrantegra
    after I post I saw that also. I change the whole unit on mine but it was for a 2008 civic si.
  5. project/driven
    Check the boot over the top of the clutch pivot. If it is torn or missing there may be contamination on the input shaft. When the throwout bearing slides that is where the squeak comes from.
