After several flashes, new plugs and a coil I'm finally tuned to stage 1! Wooooooo. Maybe I'm overly excited but I went through hell to try and get that coil covered under my extended warranty, but it only misfired with stage 1 map installed. Long story short, it's tuned and although it's only an 8% increase I'm sure I can tell a difference! Here's to achieving stage 2 by the end o the summer. Cheers!
^ Let the sickness set in. You will always want more, and when it comes to a point when you think you have too much and down grade, you will always miss it.
Boost gauge and window tint will be done soon. Next will be a DP and turbo back exhaust and obviously stage 2 map flash. The exhaust is an overwhelming decision. So many different manufactures look/sounds.
Just do yourself a favor and save some money by buying a used one. No reason to buy new...it's like buying a new car, the depreciation sucks. Again, congrats on the new powah!
^ you're talking about the tint right? DP and exhaust I'm assuming... Got anything for sale for 08+ wrx ?!
DP and exhaust...you should buy used. Tint, you should go to Chris Welcke at Flawless Front Ends!>> http://mnsubaru.com/threads/window-tint.28588/ Nope, i don't have anything...but between here and NASIOC, a used one shouldn't be too hard to find!
Going to hit up the guys over at Tintmasters in Burnsville for the tint. I know Brian over there and he's installed some audio for me in the past. Anyone had good/bad experiences with this shop?
