stage 2 ?
Discussion in 'Modifications And Maintenance' started by 054eatwagon, Jan 4, 2010.
  1. 054eatwagon
    054eatwagon Well-Known Member
    i will be picking up a catted erz dp soon from the fs section , i am also ordering....
    gs crossover pipe-coated
    gs ebcs
    gaskets
    then i will get a uppipe , which i am thinking of a coated gs as well
    and in the spring i plan to have it installed and hopefully tuned on the same day if it works out that way (pms will be sent once i have all parts and funds for install/tune)
    ?s
    parts sound ok?
    if i go with a non flex uppipe , should i go for the perrin/hks , or get a cheapo non flex off ebay?.....i heard the larger diameter can hurt spool
    any thoughts / suggestions are welcome , thanks
  2. strangefamous
    EDITED.... I read wrong. need coffee
  3. putz
    putz Well-Known Member
    GASKET/PORT/PIPE DIAMETER DOES MATTER. a good match is important. you want to be certain that the gasket is a good match for the up pipie, and that the up-pipe diameter is a good match for the turbine in-let side port. smooth flow for pre-turbo exhaust is important. otherwise you could loose power from the turbulance you create by mismatching pre turbo piping.
  4. 054eatwagon
    thanks , any suggestions for a stock turbo?
    i am thinking of a perrin up pipe....
  5. readymix
    I'd just get the GS uppipe, the price isn't bad from what I remember, and it's local. The HKS is also a decent choice for a non-flex.
  6. putz
    why non flex?
  7. SubieDave
    SubieDave Well-Known Member
    Aren't uppipes with no flex a pita to install? ..from what I've heard..
  8. wall of tvs
    not really....you just have to make sure to torque all of the nuts/bolts in the correct sequence.
  9. readymix
    Because while flex section failures are rare, they happen. It's one less thing that can fail in your exhaust system.
  10. putz
    flex failure..... or stress cracks.... catch 22....;)
  11. john
    john Well-Known Member
    I'd go with a used STI uppipe. OEM fit & finish, can be had cheap.
  12. readymix
    Wrap your uppipe. And that shouldn't happen. I've never seen stress cracked uppipes before.
  13. putz
    when there is no flex joint in the exhaust it sure as hell can happen, just as likely as a flex failure.
  14. hella_sti
    hella_sti Well-Known Member
    whatever you get, wrap the uppipe and your inner CV joint boot will thank you. I couldn't beleive how much more weathered my passanger side looked then my driver side boot, all the heat just cooks the thing! Might as well wrap the dp too, why you getting a catted one anyways?
  15. 054eatwagon
    thanks , i will get a gs up then , i was a little worried about the flex failure thing
    or...... a great option if i can find it would be a sti uppipe...06-07 are not catted right?
    i will wrap it if i get a gs....any how to right ups for that ?
    the reason for a catted dp is i want to keep the noise down in my wagon , the one in the fs section is basically the same one i had planned on getting but with a cat...so i figured i would spend a little more , get one that has a cat , and help out someone who wants to sell
  16. readymix
    All STi uppipes are un-catted.
  17. 054eatwagon
    cool , thanks
  18. Mr. Derek
    Mr. Derek Well-Known Member
  19. 054eatwagon
    thanks for the info
  20. 054eatwagon
    so i picked up an 06 uppipe , a downpipe , and a gs ebcs
    what else do i need to get before i have it installed and tuned? i know i need...gaskets and vaccum lines and maybe wrap for the dp
    any thing else you could recommended for a stage 2 on a wrx?
    thanks
  21. wall of tvs
    You'll be fine with what you have for now since the stock injectors will max out before the turbo does.
  22. 054eatwagon
    thanks , i just want to be sure i have all the misc. parts for the install , might get a pump and inj. right away as well
  23. Shibbs
    Don't! Then you'll just say "oh now all I need is a turbo!!" and then you'll be broke.
  24. 054eatwagon
    thats the plan , turbo anyway , but i was thinking next spring , so i may just wait and start getting parts along the way , thinking of a 68HTA for next year , but i think i would be better off doing the tranny work on my auto first :(
  25. heavy hauler
    heavy hauler New Member
    let me know how you like the erz i am thinking about getting one. the price is right.
  26. retreif
    I had a year old megan racing uppipe flex section fail. There is even a photo some place on here of it. I replaced it with a Grimmspeed one.
  27. 054eatwagon
    when i get it installed i will let you know how it fits , the guy i bought it from said it fit great
  28. wall of tvs
    Megan racing makes cheap crap. I'm not suprised that it failed.
  29. idget
    might wanna talk to your tuner about that one. What if in a year or so you think that a 16/18g is too small. Makes sense to fit the injectors to the amount of fuel you will need when the time comes.
    +1. Might as well go to alibaba.com and buy from the source.
  30. 054eatwagon
    ^ thanks , i will talk with him about it when i get it tuned , i think for now i will just do the parts i have and a tune , and come up with a plan for the future
