STI pinks question
Discussion in 'Modifications And Maintenance' started by issues, Oct 11, 2011.
  1. issues
    issues Well-Known Member
    sti pinks into a 03 wrx plug and play or hardwire in new pig tails?
  2. Mr.Tran
    Mr.Tran Well-Known Member
    You'll need a tune. Other than that no modification is required.
  3. retreif
  4. issues
    thanks fir the link i didnt think that much was involved.
  5. retreif
    I used it when I switched mine out for modded ones. The GBODs suck. I did put them back because I thought they actually serve a purpose. Make sure you have new gaskets and that you don't pinch one. My first system pressure up I had an arc of gas about a foot and a half tall shoot out of the car.
  6. issues
    so just the GBOD's gaskets and new top and bottom o-rings for the injectors are the gaskets I should need?
  7. retreif
    Just the injector o rings. The GBOD just hold the injectors and fuel line in place - no gaskets that I recall.
