STi TMIC on WRX
Discussion in 'Modifications And Maintenance' started by MNRex07, Jul 27, 2012.
  1. MNRex07
    MNRex07 Well-Known Member
    I have already talked to some of the guys at the calhoun meet but i got some questions about putting the sti tmic on the wrx. I have a 04 sti tmic and i have a 03 wrx. does the sti tmic just drop right in or do i need to order new hoses for the conversion? i have been told yes and i have read no on other forums. my car has exhaust mods like new cat less down pipe and up pipe with external waste gate. my turbo is stock and everything leading up to it is stock. do i need to get my car tuned when i do put the sti tmic on?
  2. JasonoJordan
    Tune not required but to get ant performance gains you will need a retune. The ypipe on the bottom of the intercooler is differnt so as long as it came with the y pipe and a 90deg coupler you will.be good to go.
  3. MNRex07
    my y pipe is i believe stock. its the one that is in two pieces and connect together with hose. this will connect right up?
  4. JasonoJordan
    yes that will work fine. make sure you get new gaskets for when you bolt the ypipe on or you will increase your chances of a boost leak.
  5. Nuke
    The stock sti tmic elbow doesnt fit tdo4 or other mitsubishi comp housings. Fits all other vf turbos though. Just replace the elbow and it should fit.
    As for tuning. You dont NEED one. But optional if squeezing every little pony out of it.
  6. Tash
    Tash Well-Known Member
    that elbow he has on there is the same one that was on our 16g ;)
  7. Nuke
    It's possible to make it work lol. :) just a little creativity sometimes can go a long way
  8. Tash
    YAY IM CREATIVE! YAY! lol
  9. issues
    issues Well-Known Member
    It will fit with out the longer elbow if you dont fasten the intercooler down.
  10. MNRex07
    ok so i need a longer elbow does any one have one laying around that i could have or buy for cheap? I plan on getting a used vf48 but my wallet says otherwise. :(
  11. Schmittybear
    Schmittybear New Member
    Ill sell u my vf39 to make it easier :D
  12. MNRex07
    what kind of price do you have in mind?
  13. Schmittybear
    WEll i was selling the vf and the sti top mount i have as a package deal for 500 but i guess make me a offer
  14. MNRex07
    tell me about the turbo. how many miles and if there is shaft play (HA!) waste gate welded? wastegate crack?
  15. Schmittybear
    About 30k on it only reason im getting rid of it cause im going bigger wastegate not welded only boosted 14.5 psi no shaft play and the wastegate has a typical hairline crack nothing major still spools great and no problems
  16. MNRex07
    im not sure if i could buy it. im strapped for cash and im really looking for a vf48.
  17. Schmittybear
    no roblem manjust ket me know if your looking to
  18. Fienix
    Fienix Well-Known Member
    L2 use punctuation.
  19. Schmittybear
    Sorry need to work on that
  20. issues
    dont waste your money buying the elbow if you are buying an vf turbo.
  21. MNRex07
    yea im going to get a vf39... for now. i still want a vf48 but that can wait for a bit.
  22. issues
    why waste the time and money to buy the 39 just wait till you get the 48
  23. Tash
    I would agree on not buying more turbos then are needed, but aren't most of the vf series about the same? Is there really a big diff between the 39 and 48?
  24. ImprezaWrx9
    ImprezaWrx9 Well-Known Member
  25. MNRex07
    i read that the vf48 spools up sooner that the vf39. do tell me if im wrong here.
  26. Nuke
    They all spool the same. 100 -/+ rpm
  27. MNRex07
    well thats good to know. but what about the cracking on the 39 does that have any effect on boost? i run a external wastegate so it would be shut all the time. its another reason i was looking for the 43 or 48. also heard that the 43 are a little hard to find
  28. MNRex07
    I found a vf48 for sale for 300. its got a crack in it and i just wanted to know what you guys think. its no small crack and looks like it could go all the way to the wheel. is something like this repairable or not? and should i pass up on the deal?
  29. MNRex07
    bump. i know there is someone out there that can help me
