Stripped bolt on camshaft pulley
Discussion in 'Modifications And Maintenance' started by Drapes, Apr 19, 2008.
  1. Drapes
    Drapes Well-Known Member
    While trying to crack loose the bolt for the camshaft pulley, I rounded/stripped it.:mad: Anyone know how to fix that? The motor is out of the car. I keep breaking tools trying to break those bolts loose. NEED HELP
  2. Speedemon
    Speedemon Well-Known Member
    heat the bolts up then try to take them off...
  3. T-REX5000
    T-REX5000 Well-Known Member
    soaked in pb blaster overnight?
  4. Drapes
    Plenty of WD-40 was used.
  5. carl
    wd40 sucks ass compared to pb and liquid wrench
  6. WRXEcho
    WRXEcho Well-Known Member
    Spinach. Heat. Pipe wrench.
  7. piddster
    Did you use a 6pt socket? An impact is the best way to get those off. Otherwise you could grind a spot for a flathead screw driver bit and use a hand impact.
  8. bikerwriter
    bikerwriter Well-Known Member
    Did you round the head of the bolt off or strip the threads? Proper terminology ftw!
    And WD40 is NOT a penetrant like Liquid Wrench or PB Blaster. I think you need a torch now...
  9. Drapes
    I did use a 6pt socket. Impact is going to have to be my next plan of action.
  10. Drapes
    I round the head.
  11. gimmefuel
    gimmefuel New Member
  12. TSTRBOY2004
    link didnt work but I am sure he is talking about nut/bolt reverse removers.... sears or northern have them.. under $30 worth every cent
  13. gimmefuel
    exactly what I was referring to.
    and yes I failed @ teh link
