Strut removal help
Discussion in 'Modifications And Maintenance' started by matt_wong, Sep 20, 2008.
  1. matt_wong
    matt_wong Well-Known Member
    We ran into a snafu while doing my springs. One of my struts the bolt that holds the strut to the knuckle is seized. We cut the nut off, but we rounded over the bolt so it wont move. Cant really get a hammer onto it because it's the bottom one in the back. Any ideas on how to get it out.
  2. prezawagon
    prezawagon Well-Known Member
    It might be easiest to take the whole knuckle out with the strut attached and then you can get room to drive the bolt out. Just taking the axle out might give you enough room too.
  3. matt_wong
    how hard is it to take the axle out i've never done it before.
  4. prezawagon
    It's not too hard, usually... There's a large nut holding the axle on (32mm I think). That nut has a lock collar on it that you have to straighten in one spot. Otherwise you just need a good impact or a good breaker bar and you should be able to get it loose. You might have to put a wheel back on and lower the car to keep the hub from turning. You can take the center cap out of the wheel to access the nut.
    Then, the axle is on splines in the hub, it should slide out, but you might have to drive it to get it started. Just don't hammer on it directly too much and mushroom it out.
  5. matt_wong
    May try that, any more suggestions.
  6. TSTRBOY2004
    air hammer is your friend now that you screwed everything else
  7. Dynapar
    Well you can always drill it out. It will take forever and will suck to an extreme but sometimes it is the only way to get some bolts out.
  8. StartRestart
    we tried drilling but it's in a horrible place and not quick the easiest bolts to drill out. Probably is the best option though Matt >.>
  9. silver03
    Does craftsman make some sort of tool for rounded bolts?
  10. TSTRBOY2004
    there are sockets for that... but depends on how bad it is screwed up...
  11. Scuba Steve
    yeah, taking off the hub assembly might be the easiest, but it will take some time.
    Otherwise I'd find a 1/2" socket that's closest to what head (bolt head) you have left. Torch the bolt head until is blazin red and hammer the socket on to the bolt. Then immediately hit it with a breaker bar.
  12. matt_wong
    Think i'm going to go see if sears has a damaged bolt remover that's large enough. Youre suppose to be able to easily slide the bolt in and out correct. If so I'll get a file too.
  13. Scuba Steve
    supposed to = yes. Do they ever = rarley. especially if they've been in for a few years without being removed. Then those bolts can be tough to get out
  14. silver03
    or a dremel with a cutting wheel.
