stumble under ANY acceloration (need local mechanic)
Discussion in 'Modifications And Maintenance' started by LASERBLUE135, Mar 19, 2012.
  1. LASERBLUE135
    Richfield
    2002 wrx
    Just last night I went for a drive and had siginificant stumble and loud popping from exhaust under acceloration. This morning on the way to work I had the same issue. Even as I was cruising in rush hour traffic under very minimal acceloration at 40mph. The car drives OK? if you are gentle, but if you try to really get moving it is very unhappy (the stumble becomes very significant/violent bucking).
    Mods: exhaust, intake, cobb AP v1
    No recent maintenance car has been great all winter.
    Note: This car was worked over by Dan (turbo turtle) last year and ran near flawlessly all winter. Dan is gone and I NEED A NEW SUBI MECHANIC!!! PREFER SOMEWHAT LOCAL. I'm by the Mall of America. Available almost any evening. I would really like someone to look at the car ASAP. Thanks for any help.
  2. idget
    falcon heights
    Check engine light?
    RSMotors is right in your area.
  3. LASERBLUE135
    Richfield
    No CEL. I've got 6 gauges (a/f, oil pressure, temps) all appear to be normal. I've been to RS with my old car. I'd prefer a garage mechanic for starters. If this is a significant issue then I will look further.
  4. Nuke
    Saint Paul
    Have you tried cleaning your maf sensor?
  5. LASERBLUE135
    Richfield
    I will do that! Thank you. Good place to start.
  6. FuJi K
    St. Paul, MN
    get at Matt@RS
    He'll gladly take care of you and I'm sure he can have Ron tune your car to bring the most out of it as part of their diagnosis package.
  7. LASERBLUE135
    Richfield
    removed.
  8. tangledupinblu
    MNBugeyeMafia#001
    +1! Matt and Ronnie are the most reliable shop that you could take your car to! Sure it's not as cheap as someone cranking away on it in your garage, but i have no issues at all with giving them my hard earned money knowing that the job is done and done right. They are absolute perfectionists and stand by their work! Good luck finding someone to do that out of your garage.
    You will not be sorry with the outcomes of their work...i promise you that!
    I personally know Dan too and he's a great guy also...he loves turning wrenches.:)
  9. Ronnie@RSmotors
    Sounds like you are not getting enough fuel. Maybe a leak before the turbo or fuel pressure dropped. Just going with your description.
    There are plenty of guys here with good experience who can help you. Even if you wanted to try to fix it yourself. If you end up still needing us, we are here to help.
  10. LASERBLUE135
    Richfield
    Well I got a CEL today. Misfire in cylinders 2,3,and 4. I have NO experience and can not do work myself. Sigh... I'll probably be giving you a call soon.
  11. JasonoJordan
    when was the last time you changed your plugs? I can give you help diagnosing/possibly fixing the issue if you want to get ahold of me pm me and we will work something out. Im down in burnsville.
  12. LASERBLUE135
    Richfield
    Plugs were replaced 15k at the stealership
  13. scotty
    scotty Well-Known Member
    St Paul
    Could be coil packs, but odd to have 3 of them go at once. Seems more like a fuel problem than spark
  14. LASERBLUE135
    Richfield
    Car will not start... Turns over great, but just won't fire.
  15. Ronnie@RSmotors
    Now it's easier to diagnose.
  16. LASERBLUE135
    Richfield
    I'm going to have it towed to RS probably some day this week. We'll go from there.
  17. Back Road Runner
    Oronoco/Rochester/Mankato
    Old car: check grounds. If you can't take a multimeter and read a dead solid zero between any sheetmetal you touch anywhere on the car, your grounds can be improved. This will influence sensor function and even function of the ECU.
    The next step is front O2 sensor (air/fuel) and MAF sensor. Both of these have a LOT of authority over how the engine runs. The trick for checking O2 is that it will run great cold and during heavy throttle while it's reading from the ECU maps but run bad under part throttle when it's reading from the sensors. A MAF is typically the opposite. A bad MAF can start and idle fine and work under very light throttle but act crazy bad under heavier throttle. You are very much describing the later, so I'd point you straight to the MAF. Cleaning will likely do nothing, but it's a cheap try. You will more likely need to replace it.
  18. LASERBLUE135
    Richfield
    ^^^ good info. The car is at RS. I'll keep you posted on what they find.
