stupid sunroof?
Discussion in 'Modifications And Maintenance' started by that-dude, Apr 29, 2009.
  1. that-dude
    that-dude Well-Known Member
    who else hate sunroof beside me, anyway, the damn stupid sunroof on my t-leg wont closed. it makes a clicking sound when the closed button is pressed. any suggestion?
    i need to get rid of this thing.......
    who can weld my sunroof shut?
  2. snowman
    snowman New Member
    Well, as far as I know, if its clicking, the switch and relay seems to be working properly, in my opinion, it may be the motor itself has gone bad....
    Id say check out some aftermarket places in your area that does sunroof installs, shy away from the dealer on an instance like this, and you may get out cheaply if you dont feel comfortable in attacking this subject by yourself.
    Oh one more thing, check the fuse!
    Good luck!
  3. bobafett04wrx
    bobafett04wrx New Member
    This is the reason I would never buy a car with a sunroof.
  4. pksublime
    pksublime Well-Known Member
    i have always had and probably always will have a sunroof. however, i much prefer the old manual tilt or remove style ones. the head clearance in my wrx is severely reduced because of that thing.
  5. snowman
    snowman New Member
    Yeah, I like my sunroof and the lil' amenities. When they're working you don't know it's there, but when it's broken, it sucks ballz. :emo:
  6. that-dude
    will do, thanks
  7. phi11
    I love my sunroof,
    cleaning the tracks and lubing all the moving parts helps,
    I do that once a year.
  8. that-dude
    i'll look into that after work, thanks guys, appreciate it.
  9. Threshld1
    Threshld1 Well-Known Member
    IIRC on the BC's there is a plug in the middle rear of the headliner. Pop that off and you have access to the motor. There should be a key of sorts for it either under the center console lid or the trunk in the black case under the floor. With this you should be able to manually crank it closed.
  10. mrantegra
    mrantegra Well-Known Member
    I loved my sunroof in my integra, now I miss it.. wish the wrb came with a sunroof..
