The flashing CEL light with CEL OBD2 results
Discussion in 'Modifications And Maintenance' started by demong, Aug 2, 2008.
  1. slobright
    slobright New Member
    Yeah they are at the dealership. You just unbolt the headers from the block and peel the old gasket off slide the new ones in and tighten but not to tight just till theay are snug...Also I don't think I need to tell you this but make sure the block is cold.
  2. AWDimprezaL
    Do you want a freakin' cookie? I'm gonna hafta ask this one more time...WHY ARE YOU STILL DRIVING IT WITH ALL THESE ISSUES!? Its like having a broken arm and showing everyone its broken by flopping it around. I guess the WRX is getting inexpensive enough that any jackass can get one :roll:
  3. esperunit
    esperunit Well-Known Member
    wow this thread is a train wreck.
    Demong, you have subaru technicians telling you how to fix your problem for $10 and you are ignoring them. If you cant unbolt your headers, put some gaskets in there and bolt them back on I have NO IDEA why you are looking for a zillion other less easy and stupid fixes.
    congratulations, you took most of the remaining life off of your motor because you were too cheap to but some cheap gaskets and too thick headed to read good advice.
    Might as well sell that car now because that engine is crap now.
  4. tbone
    tbone Well-Known Member
    if you don't want to do it yourself, I can do it for you for 100 bux replacing the header gasket:)
  5. Scuba Steve
    I would never charge that much..maybe 95 though;)
    demong, personally I'd replace the exhaust manifold with a stocker and throw some new oem gaskets in. do this asap! forget the POS manifold you have, take it off.
  6. demong
    demong Well-Known Member
    I just got some 2002 subaru wrx oem exhaust manifold gaskets today from the dealership. $50.00 cash.
    But anyways,
    whats the science behind the heat wrap?
    I got some heat wrap on the pipes?
    fyi,
    bought it stage 2 from a friend,
    but can anybody explain why I have fabricated heat wrap on the pipes?
  7. demong
    I was reading another thread called exhaust question and do you guys think i should stick some gasket maker stacked onto the oem exhaust gaskets?
  8. demong
    RTV???
  9. slobright
    I think you should be more concerned with the damage you have done to your block then the fancy-shmancy wrap on your exhaust.
  10. driftin240
    driftin240 Well-Known Member
    If they are stock pipes, they should have shields on them instead of any wrap. If they are wrapped, it's because the shields were taken off. Wrap works, as long as it stays tight.
    Now, before you blow your engine up, put the stock collectors and cross pipe on.
  11. driftin240
    Don't apply anything to them. Just put them in the way they are.
  12. demong
    thanks guys for the info,
    more info is always welcomed,
    i'm still a subie newbie all advice is welcomed
  13. driftin240
    Just fix the issue, before your engine decides to hate you!
  14. Nuke
    they're some crappy headers which i told him to take off.
    told him to get the stocker, toss it back on and call it a day.
