Things are kinda comming togather: Motor Build
Discussion in 'Modifications And Maintenance' started by putz, May 27, 2009.
  1. putz
    putz Well-Known Member
    Well, I have got:
    -ported ej205 heads,
    -fair condition ej205 short block, I could recondition this... or build it
    -Eagle h-beam rods
    I need to get:
    -head gasket kit
    -head studs
    -main and rod bearings
    -pistons(if I'm building this up)
    -oil pan and other bock acsessories
    if my goal is to run a round 300 awhp and the occational 75 shot No2, do I need to build it up? or could I reuse the stock parts (piston, con rods, etc...)?
    Is it worth it to install sti Cams, and shimless buckets? Or re-use good valves (only 20,000 mile on them)?
  2. putz
    also
    06'-07' wrx cams, .... are they the same as sti cams? and are 05'+ sti cam any better than 04 cams?
  3. Bielke55
    While its tore apart... why not build up?
  4. putz
    well, the idea is buget build.....
    but thats what I'm thinking too, I've allways been the "why not!" type guy....:cool:
  5. AWDimprezaL
    Those are some pretty high numbers, what kind of EM are you thinking? I say good luck, but ive always thought of the ej20 as made of glass...but this is just my opinion.
  6. n1ck
    n1ck Well-Known Member
    Will the AVCS 2.5L cams work in an EJ205?
  7. putz
    kinda going with what ever falls in my lap, I'm going to start with the motor, and kinda work my way out...
    as to not get overwhelmed... this will be a long term project. I think from what I've read the ej205 has its limitations, but it is not quite made of glass, the heads were $127.00, the short block was $100.00, I'm going to continue to peice this togather as it comes.
    next I have to decide what to do for pistons, would stock cast peices hold up to 300awhp? I don't think so... buy what do I know?:(
  8. Nuke
    the 06-07 wrx cams are the same as the sti cams, the sti, 04-07sti have the same cams.
    you can put the 2.5l avcs cams into the ej205 head, but won't be able to control the avcs (without a few other things)
  9. putz
    with some work... yes.
    and I'm up for some work.:cool:
  10. putz
    thanks, I think some mild cams would work well with the ported heads, and full exhaust, I think with the combination of the cams and ported heads I'd loose low end, but gain slightly in top end. With out cams it is hard to imagine too much bennifit from the ported heads.
  11. Nuke
    buy rich's kelford 272, good price on them
  12. RichWRX
    RichWRX Well-Known Member
    Karen is close to 300whp on her 2.0 wrx auto on cheap pump gas, her only mods are injectors turbo and exhaust. It hasnt blown up yet :)
  13. RichWRX
    I think their sold, just waiting on $
  14. putz
    PROLLY, but $600.00 is still steep for me, I'm looking to find what small improvment I can from sti cams. I think If I do go for a high flowing head + Cams + Larger turbo (thinking T03/04, or holset) I should be quite laggy... but I would hit my goal hp before N2O...
    I figure I can afford to be a little laggy if...
    I'm running:
    -4.111 diff
    -nitros to aid spool
    -e85
  15. putz
    GOOD TO know, what turbo?:cool:
  16. Paul Revere
    ^ Element Tuning GT49
  17. Roon
    Roon Well-Known Member
    Wait....what? I must be way out of the loop. When did you get rid of your 06-07 WRX?
  18. Paul Revere
    I don't think he has but he hasn't driven it in quite some time.
  19. goodhart
    goodhart Well-Known Member
    The 07 is going back to stock so he can haul the kid around without breakin her neck lol
  20. putz
    yes, this....^^^^^
    I kinda want to sell it too though... The car payment is such a drag.
