Timing Belt Thread
Discussion in 'DIY Instructables' started by MNSnoDrifter, Oct 26, 2008.
  1. MNSnoDrifter
    can we get a sticky for parts when replacing a timing belt, i found some stuff but its kinda a bit here a bit there, so mainly I was looking for what part u should replace and possible good places to get them if bought individually and recommendations for part brands.
    **Edited To Help out with Timing Service Questions**
    OEM Subaru Parts Involved with Timing Belt.
    (With MNSOC Discount!)
    2.5 N/A SOHC
    Timing Belt - 13028AA230 = $71.96
    Tensioner - 13033AA042 = $119.96
    Smooth Idler Pulley 1 - 13073AA142 = $59.96
    Smooth Idler Puller 2 - 13073AA190 = $33.48
    "Cogged" Sprocket Pulley - 13085AA080 = $65.46
    Water Pump - 21111AA007 = $79.96
    W/P Gasket - 21114AA051 = $3.18
    Cam Seals - 806732150 x 2 = $6.42 each
    2.5 N/A DOHC
    Timing Belt - 13028AA072 = $63.96
    Smooth Idler Pulleys - 13073AA142 x 2 = $59.96 each
    Cam Seals - 806732150 x 4 = $6.42 each
    2.0 Turbo DOHC
    Timing Belt - 13028AA240 = $119.96
    Small Idler Pulley (2002) - 13073AA200 = $33.48
    Small Idler Pulley (2004) - 13073AA230 = $63.10
    Ntxhuav_Khang likes this.
  2. Ej22TIM
    Ej22TIM Well-Known Member
    you need the belt, and the tensioner which are avail at minnetonka morries for a pretty good deal with mnsubaru discount.
    also a good idea to replace the water pump and thermostat while youre in there because you need to remove the timing belt to replace the pump anyways.
    check all pulleys for play and that should do it.
    Sanjay raval likes this.
  3. Chux
    my list, and where I like to get the parts (OEM is nice....but for the most part, unnecessarily expensive, even with the discount).
    belts, pulleys and tensioner. I would check and only replace the pulleys as needed if it's the cars first tbelt change, after that, I would replace them all, regardless. There are PCi (preferred components, inc.) kits available on ebay (like this one) for a good price. I've run these kits on many of my cars with wonderful results. definitely OEM quality for much less.
    water pump. Beck/Arnley brand from RockAuto.com (again, I use this brand for numerous parts, clutch, water pump, brake calipers, etc.....OEM quality for less, NOT remanufactured!!)
    Thermostat and gasket. just go OEM. don't skimp here, they really don't cost enough to justify cutting the corner. OEM ones are available from RockAuto.com as well. and last time I checked it was less than the morries discounted price....
    the 90* hose from the water pump to the heater line. again, if this is the first time you've been in there, just check it, after that, replace it no matter what. Just pull off the old one and take it to a parts store, they will probably have something that will fit just fine in stock. also get a pair of real live hose clamps for it.
    Crank and Cam seals. this is like $20 in parts, and $300 in labor to do separately. do them now. awesome quality Viton seals available from Smallcar.com for a great price.
    If you've got the engine out (not necessary.....but maybe you're doing clutch too....I dunno). rear main seal, again Viton from smallcar. also replace the seals for the access holes. same deal, cheap to buy, big project to replace. OEM from your local dealer is the way to go here. ditto on valve cover gaskets/grommets.
  4. Snowbum
    Snowbum Well-Known Member
    ^^ That is perfect. Tons of info.....many people say you dont need to do camseals and such, but if your in there already, you might aswell replace them.
  5. MNSnoDrifter
    what about the t-belt guide?
  6. Snowbum
    you dont need a new one
  7. Snowbum
    its not a moving part, so it will never break down.
  8. pksublime
    pksublime Well-Known Member
    i needed this info too, thanks guys
  9. KA-T_240
    KA-T_240 Well-Known Member
    What have you guys that have paid to have the timing belt done paid for parts and labor?
  10. SubiDG
    SubiDG Member
    i would also like to know the prices..
  11. Snowbum
    IIRC (I'm going strictly off of memory here) w/ mnsubaru discounted price.
    Tensioner - $80
    TBelt - SOHC $85 DOHC $115
    Waterpump w/ gasket- $80-100
    Thermostat - not sure, I think between $15-30
    Also need engine coolant....
    I think those prices are good for a ballpark figure, but one of them boys at the dealership should check my memory, LOL cause I know its not too good.
    The waterpump gasket is leaking in my Outback. I'll gladly take pictures and do a step-by-step write up on changing a timing belt. Its very easy to do, however, any mistake could ruin your engine......making it alittle intimidating. Anybody with good directions should be able to figure it out.
  12. SubiDG
    SubiDG Member
    bump my car is coming up on 90 k should i change this now?
    anyone wanna change it for me?
    pm me
  13. Iroc-Z
    Iroc-Z Well-Known Member
    I did mine at 90K. I replaced every roller, hydraulic tensioner, timing belt, water pump, and thermostat.
  14. SubiDG
    SubiDG Member
    how much did everything cost ya
  15. jrthechef
    jrthechef New Member
    just had this done along with an aftermarket radiator at morries in b.p. in the end i spent about 1800.00
  16. SubiDG
    SubiDG Member
    i pm'ed you guys
    also when i buy the thermostat does the gasket come with it?
  17. Snowbum
    IIRC thermostat gasket comes preinstalled
  18. Iroc-Z
    Pm'd you SubiDG
  19. MBOUTBACK
    MBOUTBACK Active Member
    I'm going to do my Timing Belt this weekend. I've got a 2000 Outback, and I'm looking for OEM or better parts.
    I'm wondering why I wouldn't go with Billstien T-belt Tensioner from Car Quest for $50 less than Dealer.
    I can also save 25 on the belt itself from Car quest. (MBL - OEM)
    The Water Pump would be 69 rather than 133.33.
    Idlers and pulleys each have a 10 to 20 dollar difference.
    Thermostat is 14 rather than 27.
    I guess I have two over all questions.
    What parts do people recommend spending the extra cash for "Genuine Subaru"?
    Also, any specific recommendations for parts? Or suggestions?
  20. natehack
    natehack Active Member
    ^^ Did you try the less expensive parts? ^^^
    Please let us know how they work out.
    Our service is coming up in a bit and we are not super excited...
  21. AWDimprezaL
    Timing belt componants are the last thing you should cheap out on. Just my .02
  22. cptcorn
    cptcorn Active Member
    This is something I need to look into... I have a 113k on this Forester, nothing looks old, and nothing looks new in this region... so I'm on the fence. No records came with it.
  23. StartRestart
    you could remove a side of the tbelt cover (has 3 segments), really just 3 bolts i think, and check out the belt for condition
  24. emjayem
    emjayem Well-Known Member
    while you are in there, I would recommend pulling off the oil pump and replacing the O-ring behind it. Otherwise we use the Continental timing belt kit from World Pac. comes with all new idlers and belt
  25. prezawagon
    prezawagon Well-Known Member
    Ok, all questions are for an 03 wrx with 101k miles.
    Cam seals. Should I plan on changing them as preventative maintenance? Or only if they show signs of leaking? I didn't change them on my wife's car and now 40k later one of them is leaking pretty bad and I have to take it apart again, but that's a '99 and has the old black color seals. I heard the newer brown ones last longer?
    Cam gears. If I replace the cam seals, I read somewhere the three plastic cam gears are not reusable, once they come off you need to replace them? Is that true? Also, I've heard they're a real pita to get off, any tips? Do I need a special tool or can I just break them loose before I take the belt off?
    Reassembly. Is it easy for one person to align everything and reassemble the belt without damaging the valves? I know the ej22 SOHC engines were very simple to put back together, but I'm a little paranoid with the DOHC and damaging the valves.
  26. carl
    the cam gears are pretty tough to break loose. if you try it with the belt on there's a good chance you are just going to jump teeth. I used the old belt and basically made a belt wrench and had my dad hold it while I broke the bolts free (it was really hard to hold them). However, that's on an STI with avcs stuff - I think the wrx's have a flat spot on the cams (under the valve cover) that you can put a wrench on to hold them while you take the gear off.
    re-installing the timing belt was pretty tough - I don't think I could do one by myself the first time (we did it 3x's on my engine and even after that I wouldn't do one by myself).
  27. Dirtywagon
    Dirtywagon Member
    Yeah after I read the instructions for installing the belt I was pretty scared. But after reading in between the lines it was really really easy. The belt has premarked lines on it that line up with all of the marks on the cams and the crank gear.
    The hardest part of getting my engine apart was getting the cam gears off like Carl said. luckily I had the valve covers off and was able to put a box end wrench on the flat spots of the camshaft.
  28. MNSnoDrifter
    or you can get some thing like this [​IMG]
    I have one in the garage
  29. pksublime
    sorry but what is that? also the site you linked to has the subaru specific cam holder for 145 (ouch)
  30. StartRestart
    Made this baby to help do the crank pulley on a '02 2.5l, willing to rent it out if someone needs.
  31. Nitrofish
    Nitrofish New Member
    I just finished up doing my own timing belt. WOW it was way easier then I thought. It helped that I had a factory service manual. With the manual it took me all of 5 minutes to get the cams set and the belt on. Won't hesitate to do this again. I've already told a couple co-workers that I'd do there's when the time comes.
  32. boxerfan
    boxerfan Member
    I've done head gaskets on 13 Subaru's in the last 2 years (kinda a side thing), both 2.2L and 2.5L SOHC and DOHC. Have some home-made crank and cam tools if anyone ever needs to borrow them, no charge. I'd even be willing to help a fellow sube owner out if you want, or give you my 2 cents in what I've learned. Ask anytime.
    KennyTheSubaruGuy and Windchaser like this.
  33. zyklon
    zyklon Well-Known Member
    Bump, any different parts for 2.5L turbo?
    Are cam seals still a good idea on an AVCS-equiped 2005 LGT?
  34. wrxin
    wrxin Well-Known Member
    Are all the part numbers still the same?
  35. MOsubie
    MOsubie Well-Known Member
    What do you guys think about gates timing belt? Betteror worse then oem...
  36. morganm
    morganm New Member
    EJ22 N/A Info
    Some good tips here; read the whole thread:
    http://www.ultimatesubaru.org/forum/showthread.php?t=108561
    This tutorial is about 99% of everything you need to know:
    http://www.lovehorsepower.com/SubaruDocs/TimingWaterPump.htm
    Some fairly technical data:
    http://www.endwrench.com/pdf/engine/FtEngineOverhaulSp98.pdf
    If you're gonna do seals I can't recommend this tool enough:
    Lisle - Shaft Type Seal Puller (58430)
    http://www.porcupine73.com/pics/timing/lislecamtool3.jpg
    Good debate on buying aftermarket vs OEM Timing Kits:
    http://www.ultimatesubaru.org/forum/showthread.php?t=95187
  37. turbo_turtle
    No, those P/Ns are pretty out of date, some are totally wrong. Sorry, I can't help much more than that right now.
    ~Dan
  38. TheSnowman
    TheSnowman Well-Known Member
  39. Paulwrx218
    Paulwrx218 Member
    Just a few pro tips i learned after doing my first timing belt.
    Lay a breaker-bar on the frame and bump the starter to loosen the crankshaft bolt.
    I also went to the auto parts store to rent a cam holder... Didn't work due to the lip on cam. But an easy solution is to use a vise grips to hold the two cams together. The vise grips don't need to be in Hulk mode. Just tight enough to make them lock.
    Before using the vise grips we tried to do it at least 15 times and every time ZING went the cam gear. Needless to say we worked well into the night the first time.
    Went into doing my buddies belt knowing these tips and we got it done in a couple of hours.
