To add conditioner or not?
Discussion in 'General Subaru Discussion' started by pcwerk, Jul 3, 2018.
  1. pcwerk
    pcwerk Well-Known Member
    hello all,
    I have found so many varied opinions on whether to use conditioner for a HG leak, I have
    decided to put it up here for a vote :) Our 2008 OB is definitely leaking as the mechanic
    showed me when it was up on the lift. Both sides. However, it is really not leaking any noticeable
    amount on the ground or the overflow tank. I went and got a bottle of conditioner from the
    dealer and the parts guy told me that they just got a bulletin saying they should add conditioner on
    ALL vehicles they work on with remanufactured engines. Anyway, I usually live by the "if it aint
    broke don't fix it" code but in this case I know there is a leak. What say you guys?
    jim
  2. idget
    ...that's all I got...
  3. Aegis
    STOP LOOKING AT ME, SWAN!
  4. sneefy
    sneefy Well-Known Member
    OK. Serious answer.
    I assume it's leaking coolant? If it's just oil, you can wait a while. You can leak/seep oil externally for a long time and be fine.
    If it's leaking coolant, it's time to do the head gaskets. The stop-leak (conditioner) may slow the leak and possibly delay the inevitable. Then again, it may not. But it's cheap to try.
    pcwerk and pillboy like this.
  5. pillboy
    ^^^ This.^^^
  6. pillboy
    And if you replace the head gaskets, have the shop use the ones for the turbo motor and not the gaskets for the naturally aspirated motor.
    Cotts612 and pcwerk like this.
  7. Chux
    Yep. +1 on this
    Almost all EJ253s leak oil from the head gaskets.
    The conditioner goes in the coolant. Guess what? Coolant conditioner won't effect the oil leak.
    The assumption with reman engines (I assume) is aftermarket head gaskets, which fail even quicker than OE.
    pcwerk likes this.
  8. pcwerk
    it was coolant. i will try the conditioner and hope it buys me some time...still paying off my
    mechanic for the HG job on my 99 OB! thanks for all the replies!!
  9. JaloP
    JaloP Well-Known Member
    pcwerk likes this.
  10. pillboy
    Seriously???? Do they disintegrate in the package?
    pcwerk and tangledupinblu like this.
  11. Back Road Runner
    Isn't all this warranty work?
    When did Subaru finally go to the steel head gaskets? For anything with the leak problem, this was normally the warranty repair, aka rip out the crappy stock ones and toss in the multi layer steel ones, problem solved...sort of. From that point, it just kind of depended on how flat your parts were. :p
    pcwerk likes this.
  12. Krazylegz1485
    My white man afro says always use conditioner.
    MrBlue, pillboy and tangledupinblu like this.
  13. tangledupinblu
    pillboy, Krazylegz1485 and Aegis like this.
  14. pcwerk
    you know that is an interesting question...it has less than 100,000 miles and just turned 10 yrs this year
    (not sure of the manufacture date?). do warranties transfer ownership?
  15. pillboy
    10 year, 100,000 mile warranty...you're confusing Subaru with Hyundai.
    pcwerk likes this.
  16. pcwerk
    Oh, ok
  17. pillboy
    I do agree with you though that replacing head gaskets that early in an engine's life is just not acceptable (did our Outback at 124,000 miles). Subaru should truly be ashamed of that gasket design instead of acting like there is nothing wrong.
    Cotts612, Krazylegz1485 and pcwerk like this.
  18. tangledupinblu
    They do the same thing with the EJ2.5’s as well. “Ringlands, don’t know what you’re talking about?” -Subaru
  19. Chux
    Subaru never officially went to an MLS. They did redesign the gasket a few times, but it's still a single layer coated steel. It's pretty common to use the OE MLS gasket for an EJ255
    And no, I don't believe any are still under warranty. There was a recall for the EJ251s, which involved the coolant conditioner, and I believe extended coverage on the gaskets, but the newest of those engines is 13 years old now....
    pcwerk likes this.
