Tranny bolts and me
Discussion in 'Modifications And Maintenance' started by Colin, Jun 11, 2007.
  1. Colin
    Colin Well-Known Member
    Moorhead
    So I just finished pulling the EG33 out of the SVX I bought. Took me around 2 hrs. 30 minutes to disconnect and drain everything. Then 5 min to get it jacked up and standed.
    so thats:
    30 minutes
    + 5 minutes
    35 minutes
    where did the other hour and twenty five minutes go??
    glad you asked
    well 10 minutes to actually pull the motor.
    the remaining hour searching for 4 bolts that weren't their. Whoever replaced the transmission in this car 2 years ago, put only the starter bolts, the top passenger bolt and one of two nuts at bottom back on. Here i was thinking I've gone retarded and searching the net for something that was already done for me.
    Then it pissed tranny oil all over me and I stink.
  2. Justin
    Justin Well-Known Member
    St. Paul, MN
    ouch, i think the worst part of that story was the part where you spilled used tranny oil all over you
  3. prezawagon
    prezawagon Well-Known Member
    Redmond
    moved to modification forum. it's on-topic enough for here, :)
    yeah, the worst part of changing the axle on my wife's car was when I didn't notice the pile of grease that had formed on the ground and slid my head through it... that grease doesn't wash out easily...
  4. weggy
    weggy New Member
    Maplewood
    Omgwtf Pwn3d :d
  5. Dynapar
    Orono, MN
    That is lame they didnt put the tranny bolts back in?!?!? as for the covered in used ATF I know how that goes. When I changed trannies after the first ice race, i was laying used ATF for about 3 or 4 days, it does not come out of the hair really easy. although after you get used to the smell it isnt that bad.
  6. Colin
    Moorhead
    All purpose (grease disolving)Organge oil Kitchen cleaner in a spray bottle FTMFW!!!! I got a weird look from my wife, but i took that **** to the shower. IT worked. no more smelling!!!!
    I'll post pictures of the SVX engine bay tomorrow, you'll see why (without good lighting in my ****ty garage) I had trouble seeing that thee bolt were missing. It's like someone coated the engine bay with dark vaseline.
    Poorly maintained CArs FTL :(
  7. wagonL
    wagonL Well-Known Member
    wel...i see another gs with a 33 going in??!?!?!? and i just pmed you..hhaha well goodluck with the swap...and for radiator support..well..i have ideas for you so that you dont have to chop anything....maybe a few amount of fabrication but nothing to worry about....
