Transmission compatibility?
Discussion in 'Modifications And Maintenance' started by million, Jul 27, 2011.
  1. million
    million Well-Known Member
    Does anyone know where I could find a list of compatible transmissions for my 2002 Outback Limited (5spd manual)? I have been told that any 5spd manual out of a Legacy/Outback from 97-04 should be compatible but I would like to double check before I purchase something. I have been doing some searching online but haven't really come up with much information. I am guessing I am just not using the correct search criteria.
    Any help would be much appreciated. Thanks!
  2. phi11
  3. million
    Thanks for the info phi11!
    Pretty sure I broke something in the gearbox. It is super sloppy and will not stay in 4th gear anymore... barely stays in 3rd as well. I have a bead on another transmission with low miles and that seems to make more sense than attempting a rebuild on my current one. I'm just not sure if it completely compatible.
  4. million
    Looks like I may be swapping the rear diff as well if I cannot find a transmission with a 3.9 final gear ratio.
  5. putz
    putz Well-Known Member
    I have a 93 impreza awd tranny, has a good amount of miles on it but it appears you would also need the rear diff....
  6. NaMinesClarence
    NaMinesClarence Well-Known Member
    Buy that transmission so we can put it in already ;)
  7. million
    I'm workin' on it. Planning to pick it up soon.
  8. putz
    I'll sell it with a running ej18 attached for cheap, send me a pm please.
  9. million
    Sorry man, I have my eye on another transmission right now. Good luck with your sale though!
  10. FuJi K
    really... you have a 3.900 tranny? it should be 4.111
  11. million
    I haven't officially checked my transmission but according to every list I have seen, a 2002 Legacy Outback Limited has a 3.9 final drive ratio.
  12. FuJi K
    link me them lists......
  13. Deride
    I think it should be a 4.11, but I have seen 00-01 outbacks with 3.90's. Take the code off of your transmission bell housing and look it up. Should start with TZxxxxxxxxx I think.
  14. Deride
    Hope this helps... Looks like it should be a 3.90. Oh and the tranny code starts with TY not TZ. I'm retarded.
  15. phi11
    Check post number two.
  16. million
    Had me worried for a second. I have done the research and am pretty sure it is a 3.90. I haven't found my model listed with a 4.11 anywhere. :)
