transmission pull
Discussion in 'Modifications And Maintenance' started by mkhang, Aug 12, 2009.
  1. mkhang
    mkhang Member
    Hey so I have a 2003 WRX 5 speed. Is it pretty easy to pull out the transmission? Can I do it myself, or with a couple buddies in an afternoon? If anyone has done it before please let me know! That would greatly appreciated!!
  2. Bielke55
    Id recommended having friends... or couple good jacks
  3. cptcorn
    cptcorn Active Member
    Do it yourself! ... Get some beer... Invite some friends... All automotive stuff is easy if you take your time and think about what you're doing.
  4. Kevin
    Kevin Well-Known Member
    i had my trans out, swapped the clutch, and back in all in about 6 hours.... mind you this was pretty much by myself and using all hand tools... its not too hard
  5. carl
    having a good jack really helps the process. doing the auto in dan's car sucked - but the auto is an absolute pig, far larger than your 5spd
  6. mkhang
    mkhang Member
    There's not anything difficult i'll have to deal with is there? nothing major i have to get around/take off first?
  7. jdm4you
    jdm4you New Member
    Let me know how it go's so you can help me do my 6spd when it get's here!;)
  8. Scuba Steve
    yes, it was a pig...and having people that have pulled a transmission before helps too;)
    next transmission I pull I'll use a transmission jack...normal jacks are just to ackward.
  9. Threshld1
    Threshld1 Well-Known Member
    6 speeds are a much bigger pain in the ass than 5 speeds. About as heavy as the auto.
    OP: It can be done by yourself but its always nice to have a hand to balance it on the jack or lift it. I would support the front of the motor to prevent it from stressing the mounts when it falls forward.
    Also make sure you pull the clutch fork pivot pin and pull the fork off the TOB. Otherwise you will be swearing a lot wondering why it wont separate completely.
