trunk release doesn't work
Discussion in 'Modifications And Maintenance' started by bobafett04wrx, Mar 9, 2009.
  1. bobafett04wrx
    bobafett04wrx New Member
    Ever since I got my car back from the body shop my trunk release hasn't worked. After I picked it up I tried the release and it worked about three times, then it just went loose. I think that the cable must not be tight enough or something but I'm not sure. When I pull the release it just goes all the way back with no pop. Anyone have this problem before? Any suggestions on how to get it to work again. If there is a write up on how to do this could someone post it up please. I did a search and found nothing. Thanks in advance.
    The car is a 04 wrx.
    -Jacob
  2. Paul Revere
    Dumb question is the lock on in the trunk?
  3. bobafett04wrx
    Yes the lock works just fine.
  4. Paul Revere
    No the lock so that you can not access the trunk from the cabin? There is a small switch you flip to disable the trunk release in the cabin from the trunk.
  5. Dynapar
    ^ I think he means the release cancel switch. there is a little lever on the latch in the trunk that if flipped will make it so that the trunk release in the car doesnt work.
  6. bobafett04wrx
    yeah I checked that its in the up position, not in cancel position.
  7. KSAL
    KSAL Well-Known Member
    THe cable is probably a bit loose.... put some zip ties before the ball on the cable that relseas the trunk. it happened to my STi. i will see if i can get some pics for ya
    I'll try and go snap some now....give me a few mins
  8. bobafett04wrx
    Yeah pics of said ball and cable would be very helpfull thanks
  9. KSAL
    HEre ya go this is the best that i could get becuase of the limited light and how small the area was.... this pic is looking down into hole were the latch that holds the trunk shut is...and more let me know
    Pretty sure i just took off the cover around the latch mechanism and applied the sip ties
  10. bobafett04wrx
    Thanks KSAL I will go take a look see.
  11. KSAL
    no prob... let me know if it works for you
  12. sneefy
    sneefy Well-Known Member
    How long have you had it back form the shop? If it hasn't been very long (under a week or two), the shop should fix it.
  13. bobafett04wrx
    Well I just went out and looked at it, I am not sure whats wrong with it cuz I just pushed the cable and lever over a couple of times and it seems like the cable tightened up a bit. I then tried the release and it seems to work fine now, thanks again KSAL. Where did you put the zip ties?
    I got my car back like april or may.
  14. bobafett04wrx
    oh never mind I see the zip ties in your pic
  15. KSAL
    Mine did the same thing it got worse then kinda worked then just stopped all together... the zip ties will do nothing but help release it a bit easier... no problem glad to offer help when i can
  16. bobafett04wrx
    I put one zip tie on it just for good measure, the release pops it right open now.
    Thanks to all for help and suggestions.
    /thread
