Turbo on a neon??
Discussion in 'Modifications And Maintenance' started by salty dog, May 19, 2011.
  1. salty dog
    salty dog Member
    Does anyone have a technological reason, to explain to my cousin, that buying and paying for the install of a T3T4 turbo kit on his '04 neon sxt (2.0), is a bad idea? My argument was that he was born retarded, apparently that wasn't enough to drop the idea. So, I told him I'd ask the much more knowledgable people on this site for input. Any given would be appreciated.
  2. salty dog
    salty dog Member
    Forgot to mention that the car has 60,xxx miles on it.
  3. SurlyOldManMN
    SurlyOldManMN Omdat fok jou
    I'd start with the fact that he can pretty much buy a used turbo car for the same price once he's done fumbling around to get it working properly.
  4. me_john85
    me_john85 Member
    I say go for it, if he wants to put the time and money into a car HE LIKES let him do it. Sure he should probably get a better platform to start off with, but if he already likes his car let him modify it however he wants.
    Side note, has he looked into a salvage SRT4 donor car? Not sure how hard they are to do and engine swap, I know nothing about neons. But it might be worth looking into
  5. Talonted
    Talonted Well-Known Member
    Well actually it's not all that bad, he should run e85 sine he will have higher compression that a srt4 and e85 loves high compression, also he should invest in WIDE and STICKY tires
  6. predavore
    predavore Well-Known Member
    ...and a built tranny with LSD.
  7. MNSubie22
    MNSubie22 New Member
    Guys, you are all missing the point. Modifying a Neon is just an embarrassment to the driver. Yes some SRT4's are very very fast. But a typical neon looks terrible and is slow. End of story.
  8. salty dog
    salty dog Member
    My point exactly.
  9. EBR15
    EBR15 Well-Known Member
    Just do this. Putting a turbo on a neon would be a huge waste of money. You either end up with a slow car that runs like ****, or you do it right and spend way too much for a 13 second FWD car.
    If he's just gotta have a neon, get an SRT4. It will be faster and cheaper.
  10. AWDimprezaL
    Once he's done, he'll have a faster car than a stg 2 wrx. Mark my words, subarus are slow.
  11. idget
  12. blackozone
    Wow, that is extremely comprehensive. Nice posting for a knuckle-dragger!
  13. MNSnoDrifter
    I have a couple of friends who are into neon, and 3 of then have the non-SRT4 ones that are turbo'd. they are not that bad. He just needs to do it right though. one has a full rebuild and the other 2 have SRT swaps.
  14. Tash
    Tash Well-Known Member
    even after reading their forum, i dont know much about the neon vs. srt4 but the bodies are the same are they not? if he wants to dump this much money into his car maybe he should look at srt4s? It seems that turboing the neons isnt hard, but sounds like if you want to make good power that rebuilding the engine is needed, they said 250 tq max on stock bottom end? believe me its hard to try and tell people things, best thing to do is to sit back let it happen and if your right, you can sit back in the glory of being right. let people have the projects they want, its not your project, or your money so oh well.
  15. MNSubie22
    Meh. You have a point. But it's also your legal responsibility as this guys friend to talk him out of turbocharging a basic neon. No part of that car can handle the power. Everything would have to be done. Therefore, he needs a new car haha.
  16. Flat4
    Flat4 Well-Known Member
    Its his car. let him do whatever he wants.
  17. idget
    By your reasoning, no one on here should be modifying their stock Subaru. No part of these cars are meant to handle more than stock power.
  18. blackozone
    I would disagree with you on that. The engines do just fine on Stage 2 setups. Usually. I mean, most of the time, anyway.
  19. SurlyOldManMN
    "meant to" != "can"
  20. idget
    Locally, I can think of a little under a dozen broken ej255/257s, all at or around stage 2. Several more at higher power than that.
    But yes, I chose my words deliberately by saying "meant to"
  21. AWDimprezaL
    There are a select few subies that are freaks of nature, my car is one of these. However, you dumbasses havent learned that turbo cars usually use SOME oil, and dont ever check it, thats why you roast motors, it takes 1 minute tops to do it. Subaru makes great cars, no doubt, but they aren't idiot proof, and you people prove that all the time.
  22. BugIedIzzy
    BugIedIzzy Well-Known Member
    at what point does slow become a freak- after stage 2?!
  23. Dirtyracin
    Dirtyracin Member
    I thought they became freaks when they get bit by the Warecar, or a Vampcar, or just grow a 3 foot mohawk and pierce thier front lip spoiler and hate the world.
  24. AWDimprezaL
    Freaks of nature are well-taken care of vehicles.
  25. Dirtyracin
    Dirtyracin Member
    freaks of nature are usually crazy ugly missunderstood things like frankenstein or the platypus. ooooooor your subaru as you say? So your car could be the platypus.
  26. BugIedIzzy
    misunderstood, kinda like the vampire one better
  27. AWDimprezaL
    Unicorns!
  28. Tash
    is he planning on making this neon winless???? i think that is a very important question.
  29. MNSubie22
    False, the difference between modifying an already turbocharged car vs. taking a N/A car and slapping on a turbo is COMPLETELY different. Obviously parts need to be changed on both setups but you can't honestly say that he can turn it into a turbo neon as easily as we can switch up our setup a bit.
    And.... our factory tunes leave a ton of room for more power because they want a better CHANCE at having our cars make it to 60,000 miles or so without breaking. Therefore, many parts on our cars are meant to handle more power, but they use them so they last forever on cars with less power.
  30. idget
    You brought up "legal obligation." The only party with any legal obligation is the manufacturer, who by your admission, releases cars well within their means. Anything above and beyond that is not safe in their terms and they are held accountable for failures.
    Again, no Subaru is "meant to" be modified. Just like you think the N/A neon isn't "meant to" be turbo charged. Yes, you "can" do whatever the hell you want to either car. Stop being an elitist and let the kid enjoy the car. I'm sure he'll learn more about cars by going out and building something on his own than by picking his ass sitting on an internet forum debating why his car is superior to all others.
  31. retreif
    I'm curious, do neons with turbos use oil too? Can you run one with low oil and not have the same problems?
  32. EBR15
    Just seen way too many people blow all their money and slap a turbo on a 2 liter engine and end up with 200hp. It's a huge mistake most of the time.
  33. JasonoJordan
    Stock 2.0 twinscroll turbo=320awdhp where is the mistake in that
  34. idget
    didn't you upgrade to an STi drivetrain?
  35. AWDimprezaL
    On a stock 2.0? Time bomb.
  36. Mr.Tran
    Mr.Tran Well-Known Member
    +1 for this
  37. EBR15
    Forgot to add the FWD part, which is what we're talking about here.
  38. JasonoJordan
    Yes stock 2.0 with supporting mods. Im aware that at some point ill get the inevitable rod knock hence why im building a built, 2.2t
