up-pipe rattling when turning left?
Discussion in 'Modifications And Maintenance' started by Skarecrow, May 24, 2008.
  1. Skarecrow
    Skarecrow Well-Known Member
    I just assume this is what it could be.
    was going to do the headers this weekend, only ended up doing the up-pipe.
    now she makes a nice hard rattle when going left under throttle. sometimes up hill.
    was a version 2 grimspeed up-pipe... all heat shielding has been removed.
    any thoughts?
  2. Frogy
    Frogy Well-Known Member
    seems like it could be quite a few things, there is a fair amount of hardware that needs to come out to put the up-pipe in. what did you do with the EGT?
  3. Nuke
    he has no egt
  4. TSTRBOY2004
    well this wouldnt be the issue cause he only sells the BEST and TOP quality, but if it was an ERZ I WOULD SAY BINGO. .... ha ha ha ha... couldnt resist the dig at Justin...
    seriously though it shouldnt be the up-pipe rattling at all...
    check clearances.. you may need a second set of eyes while you turn the wheel... then of course check all bolts...
  5. Skarecrow
    man, don't frighten me with that stuff :/
    i'll pop under the car after work and take a peek.
    justin seems to think its the up-pipe rubbing on the crossover..
    i'm gonna slide under and take a peek.
    by just removing the shileding I wouldn't think it should rattle.
    it sounds like a solid piece of pipe is letting something vibrate on it. under the hood I go I guess.
  6. TSTRBOY2004
    well I am not quite sure how the up-pipe would rub on the x-over seeing as it is joined to the manifold/x-over... maybe he needs to sell you another one of his product ;)
    make sure your engine mount bolt/nut was tightened.. sounds like maybe the engine shifts during hard turns/ecceleration....
  7. Justin
    Justin Well-Known Member
    i didnt say crossover i said crossmember.
  8. TSTRBOY2004
    ^^ that makes way more sense then.. yeah.. sounds like it.. especially if he left a nut loose and the engine is shifting....
    I couldnt figure out for the life of me how a x-over and up-pipe would rub... ha ha
  9. Skarecrow
    this is what I ment to say.. lol
    whoops
