weird question auto-manual swap
Discussion in 'Modifications And Maintenance' started by Rexwagon, Mar 10, 2009.
  1. Rexwagon
    Rexwagon Well-Known Member
    Anyone know how much work it would be to do an automatic to manual swap?
    I was just sitting here wondering. Did a little searching but didnt come up with much.
  2. olayx
    olayx Active Member
    You will need the peddle, transmission, master cylinder, manual ecu and the shift linkage. That should cover of it. Find those can it can be done.
  3. idget
    What car and which transmission?
  4. aqua
    aqua Well-Known Member
    i research on this a little bit too b/c i am planning an auto to manual swap soon...i was wondering what parts i would need too...
  5. qstarin
    qstarin Well-Known Member
    There's actually now quite a few threads on RS25.com and a few on NASIOC about doing this.
    Here's a handful of links I found and were at least marginally helpful when I did my swap, there's more than one parts list in these:
    http://forums.nasioc.com/forums/showthread.php?t=378813
    http://www.surrealmirage.com/subaru/swap/swap.html
    http://legacycentral.org/library/transmission/electronics.htm
    http://forums.nasioc.com/forums/showthread.php?t=1559347
    http://www.rs25.com/forums/showthread.php?t=86304
    http://forums.nasioc.com/forums/showthread.php?t=737805
    http://www.subaru-svx.net/forum/showthread.php?t=32758
    http://www.subaru-svx.net/forum/showthread.php?t=30623
    http://www.subaru-svx.net/forum/showthread.php?t=1841
    http://www.subaru-svx.net/forum/showthread.php?t=14408
    (apparently the SVX guys do this often for the AWD).
    And like I said, there's a bunch more, newer ones on RS25 - several of which I've whored myself out in.
    I also managed to break even on my swap (after selling the 4EAT), but it was a tranny from a 93 Legacy, so..
  6. Colin
    Colin Well-Known Member
    brand new from subaru pedal assembly (every part), mastercylinder and brace + hardline cost me somewhere aroudn 200-240 for I think. Then you need a slave cylinder and all the tranny parts.
  7. fondune
    SVX owners do what for the AWD?
  8. Colin
    ^swap to manual to avoid having a broken transmission every year.
  9. qstarin
    Swap tranny's. I thought lots of them were FWD. I could be mistaken, though. Maybe they're just mostly auto tranny's?
    In any event, the SVX guys appear to do auto-to-manual swaps a lot (or post on the interwebz about it a lot anyway).
  10. TSTRBOY2004
    dont forget most rear differential gearing is different between autos and stick
  11. fondune
    Yeah, I'm not an expert, but was pretty sure they're all both AWD and Auto (stock). Sorry, was just confused.
  12. qstarin
    And you may need/want a manual ABS electronics, manual cruise electronics, starter interlock relay. Manual ECU is not likely not necessary (newer years may be different), but rearranging some things on the auto harness (or replacing it) may be.
    Blah, blah, blah. Its all in the links. (reading for yourself > listening to me babble ;))
  13. carl
    they are all auto transmissions. most of them came awd
  14. fondune
  15. AWDimprezaL
    Yes the svx came in fwd, not a lot of them though.
  16. fondune
    That's silly.
  17. Ryan
    Ryan Sled drifting master
  18. qstarin
  19. Rexwagon
    I was just wondering because this guy was offering me his 04 wrx with auto for sale. plus he had a 6 speed swap. I told him that it was too much work so I was really interested. BUt it was at a good price.
