what 16" wheels fit on 05+ LGT?
Discussion in 'Modifications And Maintenance' started by Justin, Dec 2, 2008.
  1. Justin
    Justin Well-Known Member
    I have an extra set of 16" blizzaks that i wanted to put on our 05 LGT. Are there any 16" wheels that will fit over the LGT brakes?
    Justin
  2. phi11
  3. carl
    if you can't find wheels that clear, I could use those tires justin
  4. snbrd4evr
    snbrd4evr Well-Known Member
    What about 98-01 RS rims, I'm pretty sure they fit over 4-pots so why not lgt brakes? (I haven't tested this yet on my lgt, but I'm pretty sure they should fit).
  5. ShortytheFirefighter
    I'm betting they won't. With 4 pots there's almost no clearance left, and LGT brakes are bigger than the WRX units by over an inch IIRC.
  6. WRX1
    iirc, lgt rotors and sti rotors are the same size and it is just a different caliper setup.
  7. GrimmSpeed
    GrimmSpeed Vendor
    tried 99 RS wheels last night..definitely dont fit over the calipers.
  8. Chux
    similar.
    WRX rotors are 294mm. LGT are 316, and STi are 326.
  9. wall of tvs
    IIRC, the problem with LGT brakes isn't with the clearance between the outside face of the caliper and the spokes on the wheels, but rather the clearance between the edges of the caliper and the inner ring of the wheel.
    Basically, you need a wheel that is at least 17" in diameter to work.
  10. GrimmSpeed
    GrimmSpeed Vendor
    yep, its not the caliper to spoked clearance, its the outer caliper to inner wheel clearance.
  11. snbrd4evr
    Thanks for the info, and sorry for the misinfo :( That's good to know!
